aholloway17 Posted October 23, 2015 Share Posted October 23, 2015 After remounting the tires incorrectly then fixing the road noise continues:mad: Here's what's happened so far... Federal Tires aggressive tread pattern are swapped out for Cooper CS5 Road noise continues...Replaced front left bearing New waffling sound and front end still shimmies starting at 60 Tire shop replaces three of the four because they exhibit a defect Two rims found to be out of round by 20 degrees corrected to 5 degrees (reportedly within margin) Shimmies are gone for the most part after realignment corrected rims placed on rear and still waffling Are straightened rims ever perfectly round? Other thoughts about waffling? Thanks Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted October 24, 2015 Share Posted October 24, 2015 Tomorrow morning is saturday morning, you got me thinking about making waffles. on a serious note, check all your fluid levels, and dump your diff fluids and replace look for any metal shavings. I might not be road noise, but bearing noise from anywhere 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
