762x39 Posted October 23, 2015 Share Posted October 23, 2015 Can anyone confirm if there are any Strut bars that will clear the GrimmSpeed TMIC? It seems like there isn't much room for a strut bar because the GrimmSpeed TMIC is set way back in the engine bay. Link to comment Share on other sites More sharing options...
PeterJMC Posted October 23, 2015 Share Posted October 23, 2015 I'd like to know this too... Sent from my LG-H811 using Tapatalk Link to comment Share on other sites More sharing options...
762x39 Posted October 26, 2015 Author Share Posted October 26, 2015 Anyone? Link to comment Share on other sites More sharing options...
TheMonaLisa Posted October 26, 2015 Share Posted October 26, 2015 There is just one that's fits. I don't remember the brand. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
762x39 Posted October 27, 2015 Author Share Posted October 27, 2015 well that is disappointing... Link to comment Share on other sites More sharing options...
TheMonaLisa Posted October 27, 2015 Share Posted October 27, 2015 http://forums.nasioc.com/forums/showthread.php?p=43604452&styleid=1 Second picture down. I believe its the STi flexible strut tower bar. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
TheMonaLisa Posted October 27, 2015 Share Posted October 27, 2015 Man that was tricky to find Link to comment Share on other sites More sharing options...
PeterJMC Posted October 27, 2015 Share Posted October 27, 2015 EDIT -- You beat me too it^^ I did some searching and found the answer in the Grimmspeed interest and development thread for the TMIC... http://legacygt.com/forums/showthread.php/grimmspeed-08-wrx-lgt-top-mount-intercooler-interesti-212367.html The STi Strut Tower brace (STB) fits and was confirmed by WRX USA with pics too! According to one of his posts, it's part number ST2050221010 http://legacygt.com/forums/showpost.php?p=5066385&postcount=687 http://legacygt.com/forums/showpost.php?p=5066624&postcount=690 Link to comment Share on other sites More sharing options...
TheMonaLisa Posted October 27, 2015 Share Posted October 27, 2015 If you end up buying this please post up your feedback it this thread. Curious if you can feel a difference from this strut bar. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
PeterJMC Posted October 27, 2015 Share Posted October 27, 2015 The Whiteline STB might fit. It appears to be as slim as the STi one. Whiteline STB part no KSB630 http://www.whiteline.com.au/docs/install_guides/Z294.pdf The STi brace is expensive, and doesn't seem to be easy to locate on retail sites. Link to comment Share on other sites More sharing options...
Cincy05LGT Posted May 4, 2016 Share Posted May 4, 2016 Any followup on this? Sent from my SM-G930V using Tapatalk Link to comment Share on other sites More sharing options...
Rhitter Posted April 18, 2017 Share Posted April 18, 2017 The Whiteline STB might fit. It appears to be as slim as the STi one. Whiteline STB part no KSB630 http://www.whiteline.com.au/docs/install_guides/Z294.pdf The STi brace is expensive, and doesn't seem to be easy to locate on retail sites. so the OEM engine cover protrudes farther back than the GS intercooler (and goes out to the sides farther). If it fits with the engine cover on (and the picture makes it look like it does. It should fit* My OBXT build Link to comment Share on other sites More sharing options...
Rhitter Posted April 26, 2017 Share Posted April 26, 2017 KSB630 does fit. It's not a super simple just drop in nicely installation though. Had to muscle one of the sides in a little bit. There are plastic hangers holding a metal pipe in the rear of the engine bar and they interfere slightly. The angles seems slightly off for an easy installation. But, it does work, and it's not $300-$400 like the flexible STI one. http://i.imgur.com/5u0DWvu.jpg http://i.imgur.com/QRNmbx8.jpg My OBXT build Link to comment Share on other sites More sharing options...
dukeneverwinter Posted February 12, 2019 Share Posted February 12, 2019 BUMP, Does it run much on the body where it sit behind the Intercooler? I've been doing some rallycross, and want any kind of chassis reinforcement I can get. Link to comment Share on other sites More sharing options...
Homedepotmade Posted February 15, 2019 Share Posted February 15, 2019 subscribed. I am curious myself. Link to comment Share on other sites More sharing options...
Rhitter Posted February 16, 2019 Share Posted February 16, 2019 It doesn't touch the body. It touches plastic clips. If it stops raining I'll take a look and see if there is any noticeable rubbing. My OBXT build Link to comment Share on other sites More sharing options...
