BLACKonBLACK Limited Posted September 26, 2005 Share Posted September 26, 2005 Is there a walk-through for painting my brake calipers with the subaru logo? or can somone send me the subaru logo they used. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted September 26, 2005 Share Posted September 26, 2005 Basically, you take off the wheels, clean the calipers, mask off the important bits, paint the calipers and then use a template to make the logo in a different color. Link to comment Share on other sites More sharing options...
BLACKonBLACK Limited Posted September 26, 2005 Author Share Posted September 26, 2005 do you use a squared logo or a rounded logo to flow with the round shaped caliper? Link to comment Share on other sites More sharing options...
scans007 Posted September 27, 2005 Share Posted September 27, 2005 I have a few extras (Just high temp stickers) if you want the ones I put on mine............come get them http://www.pimpmyauto.com/Pictures/Brakes/DSC02261.JPG Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted September 27, 2005 Share Posted September 27, 2005 Straight- they calipers are rounded, but not much. Link to comment Share on other sites More sharing options...
rallispec Posted September 27, 2005 Share Posted September 27, 2005 important - IF you get a spray can to paint your calipers -- Do not spray directly onto the caliper while on the car. you will get overspray on everything, despite how well you tape things off. SPray it into a plastic cup (not foam, it will dissolve right away) - and then use a small paint brush to do the work. as far as the subaru logo goes, thier are plenty of people on ebay selling them. Just put down a base coat of the color you want the emblem to be. Let it dry, stick on the decals. Paint the rest of the caliper using the main paint color. (paint right over the decals) remove the decals, and the first layer of paint should still be there, and hopefully you chose a different color than the top coat. Link to comment Share on other sites More sharing options...
AKLGT Posted September 28, 2005 Share Posted September 28, 2005 important - IF you get a spray can to paint your calipers -- Do not spray directly onto the caliper while on the car. you will get overspray on everything, despite how well you tape things off. SPray it into a plastic cup (not foam, it will dissolve right away) - and then use a small paint brush to do the work. as far as the subaru logo goes, thier are plenty of people on ebay selling them. Just put down a base coat of the color you want the emblem to be. Let it dry, stick on the decals. Paint the rest of the caliper using the main paint color. (paint right over the decals) remove the decals, and the first layer of paint should still be there, and hopefully you chose a different color than the top coat. yep. it'll look better painted on then sprayed too. didn't do the overlays but may do that next spring. Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
HansGT Posted September 29, 2005 Share Posted September 29, 2005 how long does it take for the caliper paint to dry? I was thinking of painting them while my springs are being installed. They may take to long to dry...don't know. Link to comment Share on other sites More sharing options...
rallispec Posted September 29, 2005 Share Posted September 29, 2005 how long does it take for the caliper paint to dry? I was thinking of painting them while my springs are being installed. They may take to long to dry...don't know. I waited about 15 minutes between coats -- paint was dry to the touch after 20 minutes. (takes about a day to fully cure though) Link to comment Share on other sites More sharing options...
scans007 Posted September 29, 2005 Share Posted September 29, 2005 Yeah.....that's about what I did.....first coat.....did each one, then went back over and did each one again...take'n about 15 minutes to paint each......def don't drive for a good 12 hours plus after painting Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted September 30, 2005 Share Posted September 30, 2005 It's really easy and the result is great. I love free/inexpensive mods like this. I put mine up on jackstands and just went around to each corner, making sure to give them drying time. They turn out much better if you can let the car sit without driving for 24 hours until the paint is cured. http://premium1.uploadit.org/cultofthejedi//xtsept05-030.jpg Link to comment Share on other sites More sharing options...
TSiWRX Posted September 30, 2005 Share Posted September 30, 2005 ^ +1 The bottle/box will give you the best guide on the time that each re-coat should occur. Working time as well as full-cure time should also be indicated. I actually jackstand all four corners, that way, I can simply do one caliper, and then move on to the next. If I take my time and do things carefully, then by the time I'm done with all four on one pass, I'm ready to start the next round again. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted September 30, 2005 Share Posted September 30, 2005 ^ +1 The bottle/box will give you the best guide on the time that each re-coat should occur. Working time as well as full-cure time should also be indicated. I actually jackstand all four corners, that way, I can simply do one caliper, and then move on to the next. If I take my time and do things carefully, then by the time I'm done with all four on one pass, I'm ready to start the next round again. That's what I was trying to say. Damn muscle relaxers make me loopy Link to comment Share on other sites More sharing options...
TSiWRX Posted September 30, 2005 Share Posted September 30, 2005 Mmmmmm, muscle relaxers........ Do you have enough for the entire class? <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
John M Posted September 30, 2005 Share Posted September 30, 2005 http://www.moojohn.com/subaru/caliper2.jpg Just cleaned, masked, & sprayed. They still look exactly like this after one year on the road. Link to comment Share on other sites More sharing options...
NYCdob Posted September 30, 2005 Share Posted September 30, 2005 I've done this for all my friends and usaly take them off the car and use spay high temp paint. I don't want to go through the pain of bleeding all four brakes. Do they sell high temp paint on cans (non-spray)? Link to comment Share on other sites More sharing options...
rallispec Posted September 30, 2005 Share Posted September 30, 2005 I've done this for all my friends and usaly take them off the car and use spay high temp paint. I don't want to go through the pain of bleeding all four brakes. Do they sell high temp paint on cans (non-spray)? I'm sure they do, however what i've done on all my cars is just take the spray can, spray a small bit into a cup and use a brush to paint.. just refill the cup as needed. (spray into the cup away from the car, as i'm sure you're aware) the spraypaint will be much easier to find than in a can -- every automotive store or home depot-ish store has the spraypaint. Link to comment Share on other sites More sharing options...
NYCdob Posted September 30, 2005 Share Posted September 30, 2005 I'm sure they do, however what i've done on all my cars is just take the spray can, spray a small bit into a cup and use a brush to paint.. just refill the cup as needed. (spray into the cup away from the car, as i'm sure you're aware) the spraypaint will be much easier to find than in a can -- every automotive store or home depot-ish store has the spraypaint. Yea? that doesn't affect the performance of the paint (wear and tear, bond, finish) Link to comment Share on other sites More sharing options...
rallispec Posted September 30, 2005 Share Posted September 30, 2005 Yea? that doesn't affect the performance of the paint (wear and tear, bond, finish) no, wont' effect it at all... In fact, i think you'll find thats what most people do. I've put about 5k miles so far on the Mazda doing it this way and they still look good as new. For the most part, spraypaint is exactly the same as regular paint, just thinned down with propellant added. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted October 1, 2005 Share Posted October 1, 2005 Mmmmmm, muscle relaxers........ Do you have enough for the entire class? Actually I do! The script is s'posed to last a month, but they hit me so hard I'm biting them in 1/4's Link to comment Share on other sites More sharing options...
