dellguy3700 Posted October 14, 2015 Share Posted October 14, 2015 Alright folks, advice needed. I have about 161K on my 05 Legacy GT auto (I know, I know). My nephew and I replaced the heater core at about 100k, and my nephew and I replaced the blown turbo at 125k ish. we put in the VF47, perrin up pipe, access port out of box tune, oil cooler, water pump, timing belt, new plugs. I change the oil every 3k with royal purple (not a thread to debate oil). Anyway, a couple months ago I got the flashing cruise light and check engine light. It... was misfire cylinder 3, and then after sitting for a day or two I drove the car and it got real smokey. You could smell it, you could see it lofting up from the intercooler opening in the hood. It went away, and didn't come back. Well it didn't until last week. It sat for two days and I started it up drove for a bit and at a red light it was Spicoli coming out of the pot van. I have checked all belts, hoses and fluids. Oil was a hair lower than full. everything else was normal. . Oh and the cruise doesn't work.... Thanks! Link to comment Share on other sites More sharing options...
Mike07LGT Posted October 14, 2015 Share Posted October 14, 2015 You need a new engine 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
dellguy3700 Posted October 14, 2015 Author Share Posted October 14, 2015 You need a new engine and a six speed manual? Link to comment Share on other sites More sharing options...
Jaybird2013 Posted October 14, 2015 Share Posted October 14, 2015 Did the blown turbo make contact with the housing? Did you drop the oil pan to inspect for metal flakes after that turbo blew? Link to comment Share on other sites More sharing options...
cmwilliams1004 Posted October 15, 2015 Share Posted October 15, 2015 Have you checked coil pack? I don't know about the smoke though Link to comment Share on other sites More sharing options...
dellguy3700 Posted October 15, 2015 Author Share Posted October 15, 2015 Did the blown turbo make contact with the housing? Did you drop the oil pan to inspect for metal flakes after that turbo blew? It did make contact, that is why we replaced the oil cooler. We did drop the pan and look for flakes. Cleaned the pan, and changed the oil and filter at 100 miles, 200 miles, 300 miles 400 miles, and at 500 miles. Then every 500 miles until 3000k. There was small amounts of gold flake in the oil, up until 500 miles. after that it was pretty clean. Link to comment Share on other sites More sharing options...
Merc6 Posted October 15, 2015 Share Posted October 15, 2015 It did make contact, that is why we replaced the oil cooler. We did drop the pan and look for flakes. Cleaned the pan, and changed the oil and filter at 100 miles, 200 miles, 300 miles 400 miles, and at 500 miles. Then every 500 miles until 3000k. There was small amounts of gold flake in the oil, up until 500 miles. after that it was pretty clean. Yep similar to my situation and still needed a new engine. Turbo gave the motor and possibly the new turbo Subaru AIDS. Did you pull the banjo filters and look at them? 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
KRM Posted October 15, 2015 Share Posted October 15, 2015 Sub'd for information on a friends turbo that stopped boosting. But his had no contact on the housing or shaft play. Just takes effort to turn the wheel Link to comment Share on other sites More sharing options...
gimpydingo Posted October 15, 2015 Share Posted October 15, 2015 Yep similar to my situation and still needed a new engine. Turbo gave the motor and possibly the new turbo Subaru AIDS. Did you pull the banjo filters and look at them? Sub'd for the Subaru AIDS comment! Link to comment Share on other sites More sharing options...
