RumbleRumble Posted May 24, 2016 Author Share Posted May 24, 2016 It's definitely not piston slap. I took my timing cover off and i noticed my belt moving side to side. Next week im heading down to my buddies shop and were gonna tear into everything and figure it out some more. I'll be replacing the tensioner just cause and my clutch cause its the original one Also when i rev the engine from the throttle cable when the knock happens I can feel it. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted May 27, 2016 Share Posted May 27, 2016 do NOT drive that car until you get it fixed.... NO, NO, NO, NO, don't do it Link to comment Share on other sites More sharing options...
RumbleRumble Posted May 28, 2016 Author Share Posted May 28, 2016 I have no choice. I've put over 5k since the noise has been happening on and off. Link to comment Share on other sites More sharing options...
SpecFast Posted May 28, 2016 Share Posted May 28, 2016 If it is a rod knock, remove the wire or harness clip to cylinder #2 to verify that it is from that cylinder. Once removed the rod knock shouldn't be heard. Sent from my SM-G925V using Tapatalk Link to comment Share on other sites More sharing options...
RumbleRumble Posted May 28, 2016 Author Share Posted May 28, 2016 it super hard to ear if it does still knock due to my loud ass exhaust Link to comment Share on other sites More sharing options...
jdmyang Posted June 2, 2016 Share Posted June 2, 2016 Mines started out like yours and now its in the garage. It's crazy because I just hit 60k, and I put in a new head gasket, timing belts, water pump, fuel pump etc etc and bam. https://www.youtube.com/watch?v=8GPzN2CQqdo Link to comment Share on other sites More sharing options...
RumbleRumble Posted June 3, 2016 Author Share Posted June 3, 2016 I torn the front end down on my car and the tensioner is fine. About to compression test in a couple of days. Link to comment Share on other sites More sharing options...
phantommaggot Posted June 17, 2016 Share Posted June 17, 2016 Did you ever get this figured out. I'm still messing with mine too... Link to comment Share on other sites More sharing options...
RumbleRumble Posted June 18, 2016 Author Share Posted June 18, 2016 Nope havnt compression tested it yet. Still does it won't get any worse Link to comment Share on other sites More sharing options...
phantommaggot Posted June 18, 2016 Share Posted June 18, 2016 Mine is getting worse -_- I got on it with the engine steth and even when it's warm and I can't hear any ticking/tapping/knocking I can hear a lot of noise when I put the steth right here.. http://img.photobucket.com/albums/v286/phantommaggotxxx/02%20LGT%20wagon/IMG_20160617_123818728_zpsclxmxggc.jpg~original Link to comment Share on other sites More sharing options...
RumbleRumble Posted June 18, 2016 Author Share Posted June 18, 2016 Hmmm not to sure. that is that back of the motor (clyn 4) was it ever ran out of oil or low? Also put on the cylinder head and on the bottom of the block in the same spot. Link to comment Share on other sites More sharing options...
RumbleRumble Posted October 13, 2016 Author Share Posted October 13, 2016 It's spark knock. I filled up on89 octane and use a bottle of octane booster and it cleared it. Im gonna run tons of seafoam through the vacuum and some FCI in tank. Link to comment Share on other sites More sharing options...
RumbleRumble Posted October 28, 2016 Author Share Posted October 28, 2016 The seafoam didn't seam to do a lot. I ran three bottles through the brake booster vacuum line.. Octane booster does seem to help a lot, but higher octane gas doesn't. Link to comment Share on other sites More sharing options...
Tashi Posted October 29, 2016 Share Posted October 29, 2016 I have this exact noise in my ej251, and I've put 30,000KM on it, including drag racing, tracking, towing cars (Don't judge me.) and generally beating the piss out of it constantly. So, I don't think it's fatal, but it's not a concern for me, as when this blows, I have an excuse to finally get my body harness made and finish my sti swap. Link to comment Share on other sites More sharing options...
