gtcjram Posted October 2, 2015 Share Posted October 2, 2015 I have looked at so many forums on the pros and cons of removing exhaust manifold heat shields. I hope I am not double posting. The stock turbo failed me and while replacing I decided to change the up pipe. Needless to say that on a 10 year old car my heat shield bolts had become one with the manifold and were not removable. I had to cut the shields off in order to remove the exhaust bolts. I would need to purchase new heat shields if I am going to replace them. Does anyone know if leaving these off will cause problems down the road? I cant even see how I would fix these into place without removing the manifold and drilling / tapping the original holes. Any suggestions would be greatly appreciated. Link to comment Share on other sites More sharing options...
zactek Posted October 6, 2015 Share Posted October 6, 2015 OEM shields are there for a reason; to prevent things around and above them from radiant exhaust heat and keep rubber seals/gaskets/seals from drying/cracking. You can either drill/tap and get new shields,wrap them (probably cheapest) or do what I did and send them to SwainTech for high heat coating. Probably most expensive,but most effective for keeping the heat down. Zack K. Link to comment Share on other sites More sharing options...
