hellyhans Posted October 1, 2015 Share Posted October 1, 2015 Hey guys, new member here, I'm pretty active on forester.org since I have a SF with a WRX swap. I'm about to purchase a 2007 Legacy Wagon 2.5i I went to see the car yesterday and I was unable to read the ECU with learning view. I noticed in the "about" in Learning view, the 2007 legacy is not listed. Has anyone had this issue here or is it just my tactrix cable not reading properly ( I will have to test it with my swap since it used to work with my other car to flash,datalog etc..) I just learned I can pull the codes with the Dash Instrument panel, so I will check this Saturday. Since Romraider's site is down, I was just curious about this issue. Thanks Link to comment Share on other sites More sharing options...
gimpydingo Posted October 1, 2015 Share Posted October 1, 2015 I have a Tactrix 2.0 and an 07 LGT, LV works fine for that. Does not work on my 13 3.6R. Not sure if it supports the 2.5i, I would assume it does. Link to comment Share on other sites More sharing options...
hellyhans Posted October 2, 2015 Author Share Posted October 2, 2015 I have a Tactrix 2.0 and an 07 LGT, LV works fine for that. Does not work on my 13 3.6R. Not sure if it supports the 2.5i, I would assume it does. yup 07 LGT USDM is in the list but 07 Legacy 2.5i is not. 06 is 05 is and 08 is also but not 07, it's weird. I will have to test my tactrix with my WRX swap and see if it's not my tactrix drivers since I'm using a new laptop. I never tested learning view or ecuflash or romraider with this laptop. I used to use my other laptop... Link to comment Share on other sites More sharing options...
