Nebraskasubi Posted September 29, 2015 Share Posted September 29, 2015 hi i have a 1998 subaru outback that i supercharged and am now in the process of getting megasquirted with ms2 v3.57. the problem im having is i am not recieving any crank/rpm signal at all everything else is registering and, i will provide my logs and a few pictures of how i have it setup. i believe i have it setup correctly for vr ignition followed the instructions on the megamanual for vr sensor and i also replaced the subaru 6/7 wheel with a subaru 36-2-2-2 and the tutorial i used to wire up the megasquirt here http://www.rs25.com/forums/f105/t135220-diy-megasquirt-inside-stock-ecu-case.html and have double checked all my wiring so i think the problem has something to do with the megasquirt setup. i did have this running no problem when i ran ford edis on another project of mine but im a bit confused as to why i cant get rpm with the subaru. ive been trying to troubleshoot allday and have no idea whats wrong any help would be great logs and pics below Link to comment Share on other sites More sharing options...
