stepinrazor Posted September 23, 2015 Share Posted September 23, 2015 I know the two options we have are the Whiteline Bushings KCA399 and the adjustable lateral links KTA124. I have a 2008 Legacy GT with HD Bilsteins and STI Pinks. I love this combo but my tires are wearing prematurely on the inside due to the camber issue in the rear. I'm considering from least to most expensive: 1. Saggy Butt Spacer - I think if i can raise the rear a bit the camber will improve just slightly - $30 2. Rear Camber Bushing - this one is gonna require more work (press) but it's not too bad - $60 3. Lateral Links - this one's a bit too much for what I want to do. So my question to the LGT community is what has everyone else done and how's it worked out? Who sells the Saggy Butt Spacers locally here in Socal that I can pick up from? Link to comment Share on other sites More sharing options...
StoplightAssassin Posted September 23, 2015 Share Posted September 23, 2015 I doubt the issue is camber with pinks. More than likely you have a toe issue. Link to comment Share on other sites More sharing options...
gtonstilts Posted October 12, 2015 Share Posted October 12, 2015 i have the megan lateral links, i installed them before i got my obxt aligned so i could get it perfect instead of settling for either camber or toe being out of adjustment... Link to comment Share on other sites More sharing options...
