vmialik Posted September 22, 2015 Share Posted September 22, 2015 A vacuum leak from some interesting job that was done before I owned the car should I reglue/seal or how do I replaced that part if its not too hard, its not the rubber tubbing but the some form of a plastic tube that connects to the rubber hose? Any ideas? URL of issue: http://i.imgur.com/uQydEJt.jpg http://i.imgur.com/uQydEJt.jpg 05 5EAT OBXT ST2 Thanks guys Link to comment Share on other sites More sharing options...
vmialik Posted September 22, 2015 Author Share Posted September 22, 2015 http://i.imgur.com/ZyryBQH.jpg close up of the plastic pipe in question Link to comment Share on other sites More sharing options...
Saltysubie Posted September 24, 2015 Share Posted September 24, 2015 It's hard to tell from the pictures but I think that is one of the breather lines from the passenger valve cover. If so, it plugs into a plastic tube tucked behind and attached to the back side of the intake manifold. The other side of the plastic tube connects to a breather tube on the driver side valve cover. In the middle of the plastic tube, there is a branch with another rubber hose that goes underneath the intake manifold. Remove the TMIC, the BOV hose and the main wiring harness running on the back side of the intake manifold and you'll get a good look at that plastic tube. Replacing it is a bit of a pain mostly due to the line that runs under the intake manifold but it is possible to do. There are two rubber breather lines on each valve cover. Mine were all hard and brittle and I replaced them recently. You can still get them and the plastic tube (if needed) from the dealer. That's what I used although some people use generic fuel line hose to replace those rubber lines for cheaper. I preferred the ones from the dealer. Those rubber hoses slip into the plastic tube, so the epoxy job is pretty cheesy. Being that you are Stage 2, and boost leaks are of a greater concern at that stage, I would recommend replacing what you have with something more legit. Good luck! Link to comment Share on other sites More sharing options...
vmialik Posted September 25, 2015 Author Share Posted September 25, 2015 Thanks, very sound advice. At this point I cleaned it and rtv'ed the plastic and the adapter. Had a smoke test and it looks good. At this point we are going deeper. It started with a leaky GFB BOV, then this PCV plastic, now its leaky from what it seams like a cracked intake inlet hose from updating to a VF52 turbo. So at this point I need to get a perrin one, or a solid eBay one if anyone has good recommendations Link to comment Share on other sites More sharing options...
Saltysubie Posted September 25, 2015 Share Posted September 25, 2015 AVO makes a Legacy specific intake and Perrin makes one that fits okay but was really made for the 08+WRX. The stock inlet works for a VF52 and is about half the price or less than a decent aftermarket one. I'd get a new stock one for your plans -> 2 cents... I have an 05 as well and was really not impressed by the longevity of some of the hoses and such. I ended up replacing most of the hoses in the engine. There is a thread somewhere made by Cryotune that shows typical places to look for boost leaks - it's a good read. Also, look up Turkeylord for the "blue tee replacement". Link to comment Share on other sites More sharing options...
vmialik Posted September 26, 2015 Author Share Posted September 26, 2015 happened to pick up a stock tonight of 08 LGT for $50 locally . Taking off the manifold tomorrow if anyone has a nice writeup or vid. That is welcome Link to comment Share on other sites More sharing options...
vmialik Posted September 26, 2015 Author Share Posted September 26, 2015 Also finally added my first album if anyone is interested! Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 26, 2015 Share Posted September 26, 2015 Not the best write-up in the world, but this might help you: http://legacygt.com/forums/showthread.php/diy-rough-idle-cold-start-cold-temps-lgt-07-09-155325.html Also I like how you posted your images with nice legends and stuff. Easier for us to help and understand what's going on. Link to comment Share on other sites More sharing options...
vmialik Posted September 27, 2015 Author Share Posted September 27, 2015 Thanks Link to comment Share on other sites More sharing options...
