jagris Posted September 21, 2015 Share Posted September 21, 2015 Yea I probably shouldn't be bouncing around on my strut assembly. I'm trying to hunt down a suspension clunk coming from the front passenger side. Can anyone tell me if this clunking coming from the top hat is normal? Sorry the video is out of focus. Link to comment Share on other sites More sharing options...
762x39 Posted September 21, 2015 Share Posted September 21, 2015 No that is not normal. Clunking is NEVER normal. It looks like your upper mount nut is not torqued. Link to comment Share on other sites More sharing options...
jagris Posted September 21, 2015 Author Share Posted September 21, 2015 Here are pictures of the strut rod bolt. The clunky one is the obviously shorter one. Is it really just loose? I thought I needed to spend a bunch of money on new struts.. Ill put it back on tighten it down and see what happens. Link to comment Share on other sites More sharing options...
FJuan Posted September 21, 2015 Share Posted September 21, 2015 Either the top nut is not tighten down as 762x39 mention, or the top hat bearings are toast. Tighten down the nut to see if that helps. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
jagris Posted September 21, 2015 Author Share Posted September 21, 2015 Do I need to compress the spring to properly do this? Link to comment Share on other sites More sharing options...
FJuan Posted September 21, 2015 Share Posted September 21, 2015 It would help to relieve the pressure, or put it back on the car and drop the car down to compress the spring with the weight of the car. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
jagris Posted September 21, 2015 Author Share Posted September 21, 2015 It would help to relieve the pressure, or put it back on the car and drop the car down to compress the spring with the weight of the car. Wouldn't that just put more pressure on the top hat and a less accurate torque? Link to comment Share on other sites More sharing options...
FJuan Posted September 21, 2015 Share Posted September 21, 2015 Nope, you will be compressing the spring with the weight of the car, it won't be fully compressed, but it will help. When I swap springs or shocks, with spring compressors I would just get the nut tight enough and put them on the car. Then lower it and retighten again. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
