gto7419 Posted September 6, 2015 Share Posted September 6, 2015 Target boost is 24psi (tapering to 19). Running an evo316g (out of efficiency). Im using an iwg for part throttle and a ewg for 100% throttle. Wgdc is set accordingly. I can hit 21psi around 3400rpm but as soon as I do, it starts to drop. It will go down to about 10 and then rise back to about 18. I am watching for knock closely and getting none while this is occurring. Any ideas? Link to comment Share on other sites More sharing options...
BoostSLUG Posted September 10, 2015 Share Posted September 10, 2015 What? Did i read that correctly? How the hell are you using two wastegates? Link to comment Share on other sites More sharing options...
gto7419 Posted September 10, 2015 Author Share Posted September 10, 2015 At full throttle below I start to taper, the ECU is set to close the ebcs (iwg). The mbc is set for 24psi. Mbc is on the ewg. I'm pretty sure I found the problem anyway. The iwg is way soft. My bigger issue now is that the pass side cam is not advancing. Going to swap ocv and then cam gear. Link to comment Share on other sites More sharing options...
Tuning Alliance Posted September 21, 2015 Share Posted September 21, 2015 Id just get the bracket to keep the IWG shut and dont bother. Seems like WGDC isnt set correctly as it should hold more than that, look at the wgdc in the log see if it is dropping. Contact us for all your tuning and performance parts needs! Etuning the legacy community since 2008! Follow us on FACEBOOK | INSTAGRAM [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
gto7419 Posted September 21, 2015 Author Share Posted September 21, 2015 Appreciate it. Have a baby and ewg all the time is not an option. Helper spring and some wgdc tuning seems to have addressed most of the issue. I had been building a map from scratch but simply do not have the time anymore. Taking the car in for a dyno tune soon. Link to comment Share on other sites More sharing options...
Tuning Alliance Posted September 23, 2015 Share Posted September 23, 2015 I have an upgraded internal gate spring. Does the trick, as you dont need more wastegate flow to get more boost. Contact us for all your tuning and performance parts needs! Etuning the legacy community since 2008! Follow us on FACEBOOK | INSTAGRAM [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
gto7419 Posted September 24, 2015 Author Share Posted September 24, 2015 Yeah, I'm tired of spending money.... The $10 spring seems to have fixed the issue. Link to comment Share on other sites More sharing options...
