McLegacy Posted September 4, 2015 Share Posted September 4, 2015 Hi everyone, I'm doing a shifter fix soon, and until now I had decided on buying stock bushings (the whole U-Joint assembly). Last minute, I'm having a hard time actually committing to it when I'm not sure if I should drop the extra 20 on polyurethane kartboy bushings. Could someone that has done this install give me some insight and help me decide? Thanks everyone! Link to comment Share on other sites More sharing options...
digdug18 Posted September 15, 2015 Share Posted September 15, 2015 I'm interested in this as well, for shifter bushings, which to get. Link to comment Share on other sites More sharing options...
McLegacy Posted September 15, 2015 Author Share Posted September 15, 2015 I went ahead and bought the Kartboys. Since then I've developed a much more comprehensive understanding of what to do. Here is a diagram of the Subaru shifter in our car: http://turninconcepts.com/install_forum/download/file.php?id=56 The labeled parts are all bushings. The shifter stay bushings are D (front) and E (rear). Kartboy and Cobb both sell polyurethane front & rear stay bushings here and here. What these bushings do is increase the clarity of your shifting (so you know what gear you're in). They really do make a significant difference. They DO NOT remove the horizontal and vertical slop that you feel, but it WILL make it almost not feel like a problem! In order to remove this slop, you must replace the shift linkage. The problem bushings are labeled A in the diagram. However, on our Legacies (basically pre-1998), these bushings are riveted into the linkage, meaning that you can't remove them and you must replace the entire linkage. BE CAREFUL!! Turninconcepts sells a shift linkage on their website, but THESE ARE NOT FOR OUR CARS. This is made for 03(?)+ Legacies (and other Subarus) and WILL NOT FIT ON OURS WITHOUT MODIFICATION. I don't know exactly what the modification is but I'm sure you could find it with some googling. More information about where to buy & how to install the shift linkage will be found here. Very in depth guide, many thanks to ernestedward over at ultimatesubaru.org. The vertical slop is caused by the ball in the diagram at the base of the shifter (below the C bushings) being loose. I can't figure out exactly how to fix that, but I know that with a new shifter or short throw shifter (still new) this problem would be gone. I imagine that if you punch out the pin in the center of the the sphere there would be a way to tighten it but I haven't done that so don't take my word for it. If you want help on the install respond to this thread and I'll give you tips for what I did (some of which is either not online or difficult to find). The install took me much longer than most because of my lack of tools available. What I ended up needing was this: - Jack & Jack Stands (make sure you know where to place on the frame - Ratchet - 12mm Socket - 12mm wrench (for the front stay bushing, no space for a ratchet) - Long Extension (not exactly anything, anywhere from 8"-12". I just put two together). - Universal joint (used this for the rear install) - PB Blaster (or some kind of corrosion penetrant like WD-40) Remember that the rear bolts do not screw in straight, but rather toward each other at a slight angle. To achieve this with the second bolt, use the long extension to angle the bolt rather than trying to achieve it by putting pressure on the stay bushing. Hope this helps! Link to comment Share on other sites More sharing options...
twisty Posted September 21, 2015 Share Posted September 21, 2015 In order to remove this slop, you must replace the shift linkage. The problem bushings are labeled A in the diagram. However, on our Legacies (basically pre-1998), these bushings are riveted into the linkage, meaning that you can't remove them and you must replace the entire linkage. i just went through this with my 96 outback. i couldnt get the oem parts same day, so i did the next best thing... shaved down a piece of fuel line and put it on the spacer in the linkage, smacked it on with a brass hammer. the rear holding bushing was broken as well, so i have another piece of fuel line compressed and zip tied in place to keep the shifter where it should be. when i get all the kartboy pieces ill redo it all the right way. so far, the redneck engineering is holding up well. Link to comment Share on other sites More sharing options...
