asc0205 Posted September 3, 2015 Share Posted September 3, 2015 Could anyone tell me if the sockets for the front turn signals are "CK" style (ground terminals on the same side) or normal style (ground terminals on opposite sides)? I don't have a way to test them right now and I would like to order a set of LEDs because one of the halogens is burnt out and thats a perfect excuse to put LEDs in right?? The bulbs I am looking at are compatible only with the normal socket type. DISCLAIMER: Before you say they will cause hyperblink, know that I have a speed adjustable flasher module that corrects this because I had the problem already when I installed LEDs in the rear. Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted September 8, 2015 Share Posted September 8, 2015 https://www.sylvania.com/en-us/applications/automotive-lighting-systems/Pages/lrgallbulbs.aspx?year=2005&qual=37&model=1300&make=89 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
asc0205 Posted September 9, 2015 Author Share Posted September 9, 2015 Thanks but that isn't helpful for LED application. Incandescent bulbs need one end of the coil for power and the other for ground but it doesn't matter which end is which. With LED bulbs, there is a wire for power and a wire for ground. This is a diagram of what I meant in the original question. http://www.distantxtremes.com/uploads/6/4/1/5/6415860/6135462_orig.png Link to comment Share on other sites More sharing options...
300zx2g35 Posted September 11, 2015 Share Posted September 11, 2015 They are CK on my 2009 Link to comment Share on other sites More sharing options...
asc0205 Posted September 14, 2015 Author Share Posted September 14, 2015 Thanks! Does anyone know if its the same for 05-07? Link to comment Share on other sites More sharing options...
A_Tang Posted September 14, 2015 Share Posted September 14, 2015 Thanks! Does anyone know if its the same for 05-07? My 2007 wagon uses the 3157CK. Link to comment Share on other sites More sharing options...
Diode Dynamics Posted September 21, 2015 Share Posted September 21, 2015 Our HP11 LEDs are compatible with both standard and CK-configured sockets FWIW: http://www.diodedynamics.com/store/led-bulbs/listed-by-size/3156/3157-11w-hi-power-leds Nick C. John C. Diode Dynamics Link to comment Share on other sites More sharing options...
