dinosmash Posted September 3, 2015 Share Posted September 3, 2015 are both left side window motors the same front to rear? i found info that says yes and no .my drivers window wont go down I already did the main switch. my rear interior is gutted so I don't care if the rear windows work.so I want to take the left rear door window motor and put it in the drivers front door.car is 05 LGT thanks Link to comment Share on other sites More sharing options...
dinosmash Posted September 7, 2015 Author Share Posted September 7, 2015 As it turns out you can use the same side window motor front or rear.theconnector is two pin but different .very easy to figure out.most people dont even open there rear windows so using that motor is a free fix. Link to comment Share on other sites More sharing options...
