xxBLOOD88SHOTxx Posted August 30, 2015 Share Posted August 30, 2015 Does the OTS tune delete the sensor in the stock uppipe, as in I can run a catless uppipe with a OTS tune and not have a CEL correct? Thanks for any and all help. Link to comment Share on other sites More sharing options...
mkee87 Posted August 31, 2015 Share Posted August 31, 2015 Catless uppipe works fine with ots tune. No cel. Link to comment Share on other sites More sharing options...
xxBLOOD88SHOTxx Posted September 4, 2015 Author Share Posted September 4, 2015 Right on, thanks for the info. Link to comment Share on other sites More sharing options...
Shogun506 Posted September 12, 2015 Share Posted September 12, 2015 Catless uppipe works fine with ots tune. No cel. Unless it's the stage 2 tune it doesn't delete the CEL. Stage 1 still has all of the CELs enabled, I'm looking at it right now in Accesstuner Race. That said, OP you can easily modify the stage 1 tune to delete the CELs as in this thread: http://legacygt.com/forums/showthread.php/install-catless-uppipe-invidia-224448.html Link to comment Share on other sites More sharing options...
Cornerz Posted September 27, 2015 Share Posted September 27, 2015 You can also just put a resistor in the O2 sensor circuit when you install the catless uppipe. 2.2K Ohms I believe - google knows the right answer. Link to comment Share on other sites More sharing options...
