BossCock Posted August 27, 2015 Share Posted August 27, 2015 Looking to replace my endlinks all around with the Kartboy links. http://www.rallysportdirect.com/shop/product/kar-kb-017-08combo-kartboy-front-and-rear-endlink-combo I've confirmed the fronts will fit on my 2008 2.5i, but can't find anywhere saying the backs will fit proper. I just want to be sure they'll bolt up before I order them. Any insight is appreciated. Thanks! Link to comment Share on other sites More sharing options...
rip_it Posted August 28, 2015 Share Posted August 28, 2015 Assuming its the same as an LGT, You want part #KAR KB 017 STI COMBO. I don't think the one you linked is correct. $10 bucks cheaper too. If you're staying with stock sway bars, youll be better off saving your money and buying Moog endlinks. Link to comment Share on other sites More sharing options...
BossCock Posted August 31, 2015 Author Share Posted August 31, 2015 I was able to confirm that the 2.5i and GT share the same part number on those rear links. The plan is to upgrade the sways next, so def going with the Kartboy links after everything I've read/heard about them. Thanks for the help! Link to comment Share on other sites More sharing options...
