LegaLude Posted August 26, 2015 Share Posted August 26, 2015 This may be a really easy question to answer, and I want to preface saying I have definitely searched the forums and read many threads, but it is very likely that someone just knows the answer. If I am running, on my 05 LGT 5MT, only aftermarket up pipe, down pipe, and header, what OTS tune should I be using? My car was tuned by the previous owner but for certain issues I was forced to buy an AP to discover it had a Cobb tune on it already. This tune blocked certain codes that are necessary to diagnose my problems. However, I can see that my Exhaust Gas Temperature sensor does not truly exist and has been eliminated from my system. But I am currently on the Stage 1 tune and have been seeing P0546 (I believe) EGT constant value or out of range. Something of the sort. Does the Stage 2 OTS map accommodate for this modification or do I need to approach this differently? Thank you and sorry in advance if this is as stupid as I think it is. Link to comment Share on other sites More sharing options...
whitrzac Posted August 26, 2015 Share Posted August 26, 2015 you need a 2.2k resistor. Google it, this mod has been around for over a decade. cobb strikes again. Link to comment Share on other sites More sharing options...
LegaLude Posted August 26, 2015 Author Share Posted August 26, 2015 Gah! Perfect. Thank you! Link to comment Share on other sites More sharing options...
syngen smythe Posted September 10, 2015 Share Posted September 10, 2015 i had this same question about the EGT being disconnected. And i know that on this forum there is no information on HOW to do it, and no pictures. I searched for a couple hours. and don't dare ask because you will get the wrath of the 3000+ post members telling you to search for it, rather than just answering your question! I finally found pictures and instructions on another forum. So here is what i found out on the other forum: it takes a 2.2k Ohm resistor, (some people know that 2.2k is ohms, others don't) and it should be at least 1/2 amp to last. i ordered ten of these resistors for like $3. on Ebay. i figure i can solder the correct connectors on and maybe even fab up some kind of plug that will be 'plug and play' and solve the problem. I may even post it here when i get it done. i doubt that you need to solder the connections on; you can probably just stuff it in there and tape it. Thats what they were talking about (on the other forum). Link to comment Share on other sites More sharing options...
Shogun506 Posted September 12, 2015 Share Posted September 12, 2015 Cobb OTS stage 1 tune does not delete any codes. Stage 2 deletes 0546 as well as a bunch of other codes that are thrown when those parts are swapped. You can modify the stage 1 map to get rid of these codes by using Accesstuner Race and opening the tune. Click edit->advanced parameters->uncheck the codes you are getting in error, save the file, flash it to your ECU, boom bang bing Link to comment Share on other sites More sharing options...
