bobw Posted August 23, 2015 Share Posted August 23, 2015 I just finished replacing the O2 sensor on my 93 legacy, but it's still showing code 32. Any ideas? Link to comment Share on other sites More sharing options...
wtdash Posted August 26, 2015 Share Posted August 26, 2015 Hi, Did you clear the code after replacing it? Did you check the wiring back to the ECU? GL, TD Link to comment Share on other sites More sharing options...
bobw Posted August 30, 2015 Author Share Posted August 30, 2015 I also had code 35, replaced the purge control solenoid, then disconnected the battery, reconnected it and no more check engine light. Link to comment Share on other sites More sharing options...
