leakypipe86 Posted August 23, 2015 Share Posted August 23, 2015 Just got done installing the Hellas but when I lock my car (3 presses), they go off. They are way too loud. Also, the beeping with the first two presses are gone. I noticed the stock horn assembly has two horns, each with their own connector, and a random white connection in the back. I disconnected them all and removed the assembly. Which sockets produce the stock chirps and final beep? I only want the Hellas to go off when honking the horn on the wheel. Link to comment Share on other sites More sharing options...
ras06LGT Posted August 26, 2015 Share Posted August 26, 2015 Pressing the lock three times and getting a horn beep is normal - it's a car finder function. I believe this is a BCM programming thing and cannot be disabled. The normal lock beep is also controlled by the BCM, but has a separate module that actually beeps. Can't remember where it is, but it should not be affected by a horn install. Make sure you didn't know any other connectors loose on accident. Link to comment Share on other sites More sharing options...
