Slow Posted August 21, 2015 Share Posted August 21, 2015 I searched the forum real quick but couldn't find anything, go ahead and ridicule me in the comments. Anyways, I saw the wheels I wanted on craigslist for a good price but I'm not sure how well they'll fit. How does a 18x9 with 225/40 tire do with a lowered car and how much camber is normally used to get it fitted comfortably. All 4 corners have been rolled and very slightly pulled. Thanks! Link to comment Share on other sites More sharing options...
rebourne Posted August 21, 2015 Share Posted August 21, 2015 I've been collecting info on a similar fitment for my obxt. I'm pretty sure it'll work, with no more than -2.5 camber. You didn't say how low you are, but I'll assume with a roll and pull, you're lowered. Probably much less than 2.5 camber, but I'm playing it safe. Go check em out. pic thread build thread Link to comment Share on other sites More sharing options...
rebourne Posted August 21, 2015 Share Posted August 21, 2015 From my notes, here's a reference: http://legacygt.com/forums/showpost.php?p=3882250&postcount=67 He's on 18x9.5 +30 with 225, which I assume to be 40 series looking at the stretch. So 1/2" narrower wheel and 5mm less offset of the setup you are looking at should be more than good with your roll and pull. Post pics if you get them, or even if you just test fit them! pic thread build thread Link to comment Share on other sites More sharing options...
Slow Posted August 21, 2015 Author Share Posted August 21, 2015 Thanks for the help. If I buy them I'll post a pic of the result for sure. Link to comment Share on other sites More sharing options...
Drift Motion Posted August 26, 2015 Share Posted August 26, 2015 "lowered suspension" can mean a lot of things springs? coils? spring rates? manufacture of the tire(as not all 225s are the same)? fender modification? Link to comment Share on other sites More sharing options...
asianrage Posted September 8, 2015 Share Posted September 8, 2015 You're gonna poke a whole bunch. Link to comment Share on other sites More sharing options...
