tschmidt240 Posted August 17, 2015 Share Posted August 17, 2015 im in need of some help, am i able to wire up a haltech elite 1500 into my 08 XT? idk if the canbus will get in the way, or could i wire it up in parallel with the factory ecu so the haltech does its thing and the oem ecu stays in the canbus loop? Link to comment Share on other sites More sharing options...
gto7419 Posted August 22, 2015 Share Posted August 22, 2015 I would assume from the haltech description that wiring in parallel is going to be a nightmare. You would be making the mold here if you tried, and I typically would recommend against that because you will have no support. Link to comment Share on other sites More sharing options...
