Neltech Posted August 15, 2015 Share Posted August 15, 2015 tried unmarying my access port connected the green plug while car was running. Won't start now. Tried leaving battery unplugged. Nothing. Cobb won't read codes. Link to comment Share on other sites More sharing options...
Neltech Posted August 15, 2015 Author Share Posted August 15, 2015 Er hc sorry Link to comment Share on other sites More sharing options...
whitrzac Posted August 15, 2015 Share Posted August 15, 2015 Er hc is a can bus comunication error. Are the green plugs disconected? Link to comment Share on other sites More sharing options...
Neltech Posted August 15, 2015 Author Share Posted August 15, 2015 I disconnected it, still no start. I'm going to call Cobb and see if they have any ideas. Tried a battery reset plugged in and unplugged. Link to comment Share on other sites More sharing options...
Matt166 Posted August 15, 2015 Share Posted August 15, 2015 Contacting cobb is your best bet. I had that error code after I bricked my ECU flashing a new map. Link to comment Share on other sites More sharing options...
Neltech Posted August 15, 2015 Author Share Posted August 15, 2015 I was on my way to drop off my LGT to trade it in. Bricked the bastard 3 miles away from the dealership. Its still there, 3 hours from home Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 15, 2015 Share Posted August 15, 2015 Yeah it is probably bricked. I believe you can send the ECU to cobb so they fix it instead of buying a new one. Link to comment Share on other sites More sharing options...
Code Posted August 15, 2015 Share Posted August 15, 2015 I don't want to make any assumptions, but were you being sneaky and trading in a car that should have an AP/tune on it? Flashing back to stock map without reverting back to stock hardware? Why re flash/unmarry so far from home and so close to the dealer? Karma? "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
Matt166 Posted August 15, 2015 Share Posted August 15, 2015 That sucks, but its not too bad of a job, just a bit of hassle because of the distance. Managed to get mine out without touching the center console, removed the lower door rail trim and pulled the carpet back just enough. 6 10mm bolts/nuts and a couple of connectors later and it was out. I have read that Cobb can do a pretty quick turn around if they will fix it - did you buy your AP new from them? What have they said so far? Link to comment Share on other sites More sharing options...
Neltech Posted August 15, 2015 Author Share Posted August 15, 2015 I bought the car with the AP. Cobb isn't open until Monday so I haven't talked to them at all. My car is north of LA and HOPEFULLY monday I can pull the bcm and drive it to their place Fountain Valley. Where's the bcm on this? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 15, 2015 Share Posted August 15, 2015 The ecu? I believe it is located underneath the carpet on the passenger side footwell. Link to comment Share on other sites More sharing options...
Matt166 Posted August 15, 2015 Share Posted August 15, 2015 ECU? Pass side footwell. Link to comment Share on other sites More sharing options...
Neltech Posted August 15, 2015 Author Share Posted August 15, 2015 Cool cool guys thanks. I'll give Cobb a shout monday morning and I'll reply here with my findings. Link to comment Share on other sites More sharing options...
Neltech Posted August 18, 2015 Author Share Posted August 18, 2015 I don't want to make any assumptions, but were you being sneaky and trading in a car that should have an AP/tune on it? Flashing back to stock map without reverting back to stock hardware? Why re flash/unmarry so far from home and so close to the dealer? Karma? Actually yes I was. I had no idea until I talked to Cobb today that uninstalling it and not putting the car back to stock was a bad idea. I wouldn't trade it in knowing that. I'm sending my bcm off to cobb tomorrow and when it comes back the accessport will be going with the vehicle. I fucked up. Figured i could just uninstall it and sell it. I was wrong. Now its costing me money instead of making me money. Live and learn I guess. Link to comment Share on other sites More sharing options...
