GrasshopperLGT Posted August 13, 2015 Share Posted August 13, 2015 Product: http://torcoracefuel.net/pro-accelerator.html I only fill up on 93. So adding +4 octane making 97 ok? Or would it be a must with a tune?? Car: 2005 LGT completely stock w/ 109k miles. The why? Well my uncle runs the stuff in his Raptor w/ around 800+ hp. He uses it for the extra octane and less prone to knock. Runs better and happier. I figured this: 1 oz. of Torco is $0.05 Every 5 gal of gas = $4.01 of Torco or every 1gal gas = $0.80 Torco So tank of gas roughly 15 gal = 24oz Torco / $12.03 extra. I don't know if it is worth it or not. I fill up almost every other week but say I fill up every week then it is only costing $12.03 extra a week. But can I run Torco at a +4 octane = 97 total and be ok or would there have to be a tune? (It's early and I hope that all made sense) Link to comment Share on other sites More sharing options...
battelready Posted August 13, 2015 Share Posted August 13, 2015 You'd more then likely need a tune. The GTs are tuned for gas between 91 to 93. But you arnt going to get any significant gains from it a stock setup with just race gas. I bought an auto be more involved in my uninvolvedness . 200k+ Club If you can't blind them with brilliance, baffle them with bullshit. My high mileage turd. Link to comment Share on other sites More sharing options...
Feeny1701 Posted August 14, 2015 Share Posted August 14, 2015 I recently used the NOS version of that to correct a knock I was having using launch control and flat foot shifting while running down the drag strip. I got tuned for 91 octane, and the stuff actually did work. I almost couldn't believe it, but I was logging with my access port, and the numbers don't lie. If you're not seeing any knock to begin with, it's a waste of money, and with a stock tune running on 91 or higher octane fuel, I would suspect that you are not seeing enough knock to justify the cost. I have read about the MMT causing deposits on the spark plugs or injectors (can't remember which), so be aware of that if you're using the additive a lot. From what I've read, the Torco Accelerator and the NOS Octane Booster Racing Formula are the only "Octane Boosters" that actually do work. Link to comment Share on other sites More sharing options...
