Winesalot Posted August 10, 2015 Share Posted August 10, 2015 On my 95 Legacy 2.2L Auto Sedan we have been having to add quite a bit of brake fluid. We also have had lots of problems with the anti lock brakes releasing break pressure on one or more wheels even under mild braking events. At this point the fuse has been pulled on the anti lock brakes because they were getting dangerous. When my daughter took the car to her local mechanic (she is at college 6 hours away from me) they told her the brake master cylinder was leaking fluid in to the brake booster. There is no evedence of this what so ever. The fluid is leaking on the anti lock brake unit itself. Picture below. My questions are: Can the fluid leak be fixed or should I find a replacement anti lock brake manifold and, once fixed or replaced do you think this will solve the anti lock brake release problem? (Please don't suggest I somehow remove the anti lock system entirely. My 19 year old daughter who goes to college in a snowy/icy town and her highly protective mother will never sign off on that. The whole reason for this car is the awd and anti lock brakes.) http://i1222.photobucket.com/albums/dd499/SilverBellWinery/anti%20lock%201.jpg http://i1222.photobucket.com/albums/dd499/SilverBellWinery/anti%20lock%202.jpg Link to comment Share on other sites More sharing options...
Osei Posted August 10, 2015 Share Posted August 10, 2015 Probably one or more fittings have developed pinholes. You need to find out which and replace those lines. There may be enough room to cut and flare the fittings, but a closer exam will tell you. O. Link to comment Share on other sites More sharing options...
Winesalot Posted August 10, 2015 Author Share Posted August 10, 2015 Probably one or more fittings have developed pinholes. You need to find out which and replace those lines. There may be enough room to cut and flare the fittings, but a closer exam will tell you. O. If you look at the first picture I have an arrow pointed where the leak is happening. It is on the anti lock brake 'modulator' (I think that is what it is called) Link to comment Share on other sites More sharing options...
Osei Posted August 10, 2015 Share Posted August 10, 2015 Replace with a junk yard unit. Make sure it has oil in it, take it to someone who can bleed it once it is installed. O. Link to comment Share on other sites More sharing options...
subieadam Posted August 12, 2015 Share Posted August 12, 2015 I have a complete ABS unit out of my 97 OB for sale Link to comment Share on other sites More sharing options...
Winesalot Posted August 12, 2015 Author Share Posted August 12, 2015 I have a complete ABS unit out of my 97 OB for sale It has the exact part number shown in my original post, is fully functional, and has no leaks? If so, how much? Link to comment Share on other sites More sharing options...
subieadam Posted August 12, 2015 Share Posted August 12, 2015 I replied to your PM Link to comment Share on other sites More sharing options...
Winesalot Posted August 18, 2015 Author Share Posted August 18, 2015 Success!!! I found a replacement modulator assembly at a local wrecking yard for $75 and installed it so the leak is gone. However, the problem I was experiencing with the anti lock breaks releasing brake pressure under normal braking conditions is still happening. I called the Subaru dealer and they said their computer can only diagnose if there is a fault code and the abs warning light is on, which it is not. This is a problem. Link to comment Share on other sites More sharing options...
subieadam Posted August 18, 2015 Share Posted August 18, 2015 Might want to check the ABS sensors at each wheel, clean off the magnetic tips as they sometimes get cluttered with junk that could interfere with the signal it sends to the ECU. Link to comment Share on other sites More sharing options...
Osei Posted August 19, 2015 Share Posted August 19, 2015 Unit probably needs to be bled. O. Link to comment Share on other sites More sharing options...
subieadam Posted August 19, 2015 Share Posted August 19, 2015 Unit probably needs to be bled. O. Agreed Link to comment Share on other sites More sharing options...
Winesalot Posted August 19, 2015 Author Share Posted August 19, 2015 Entire brake system has been fully and thoroughly bled. Link to comment Share on other sites More sharing options...
Osei Posted August 20, 2015 Share Posted August 20, 2015 Bleeding the brake system does not bleed the abs unit. It is separate. This is why I stated in an earlier post to take the unit to someone who can bleed it upon purchase. There may be an online procedure that can help. Try a Google search. O. Link to comment Share on other sites More sharing options...
RustyRuu Posted August 30, 2020 Share Posted August 30, 2020 I had this problem with one of my subarus it had rear drum brakes. That's where the abs would kick off on certain braking events, in the rear. I pulled the drums, had tons of built up dust, brake cleaned the sensor and where it picks up the signal on the spindle. I'd say one can per brake, get those suckers clean, its worth a shot and cheap maintenance if it doesn't work . Link to comment Share on other sites More sharing options...
