MichaelLGT Posted July 31, 2015 Share Posted July 31, 2015 I have a 2005 LGT 5EAT. Alright my radiator went out so I purchased a 08-14 wrx/sti mishimoto radiator in which I had to bypass the ATF cooling system that went through the OEM radiator with an ATF cooler. But now Ive noticed that I have 2 all together ATF coolers on my vehicle. Is that a problem? been going on for 6 months of so and havnt had any hiccups or problems whatsoever. Thanks. Link to comment Share on other sites More sharing options...
starionesir Posted August 4, 2015 Share Posted August 4, 2015 How do you have 2 coolers? The factory cooler is the oem radiator. You said you bypassed the oem cooler with a cooler? If that's the case you have one cooler and to do it properly you should have it setup with a thermostat. You should read this as it explains the issues of super cooling the the transmission and will show you how to properly install a aftermarket cooler. http://legacygt.com/forums/showthread.php/properly-plumb-your-5eat-transmission-cooler-221643.html Link to comment Share on other sites More sharing options...
