STI spring on stock Bilstein?
asianrage
So my 08 3.0R has about 102k and I'm interested in lowering the car using the JDM STI springs. A few questions for every with more experience than I
1. Should I? The struts and shocks seems stiff (if sometime more abrupt than I like) but the handling is really good. I hear that Pinks just lower the car while keeping the ride quality the same.
2. Where can I go to get replacement top hats?
3. Will KYB struts/shock combo be fine with the PINKs?
2.
JDM WRX STI springs wont fit. you need legacy specific Pink springs. Since your care already came with bilsteins, just get Bilstein HD's and reuse all of your other hardware. KYB struts is a downgrade.
Yeah, I know. I was referring to the JDM STI springs that I was going to get from JapanParts.com
I was looking at Bilstein on Amazon and I realized that the OEM offering is cheaper. Is this right? Where would you recommend I go to purchase the HD version?.
HD's and Pinks are quite stiff and harsh, FYI.
If you already think the stock setup is harsh, you won't like the HD's and pinks.
I disagree that the combo is harsh, but that is subjective.
I do agree that if one thinks the OEM Bilstein setup is harsh at times that they will likely think the Pink/HD combo is harsh.
Orly. I do like the low body roll... Is there a compromise somewhere? Koni insert with the adjustable damping turn to soft and Tein H tech?
Here's my HDs+Pinks around town.
Some of the noise is just the vibration getting to the camera, but it gives you a general idea of the NVH that I get to live with on a regular basis:
https://youtu.be/ZXnyHIKs2-s?t=44s
And on the highway: https://www.youtube.com/watch?v=0eKmW8Bn-KM
My comment was based on my own personal experience with the combo, and as I said, suspension harshness is totally subjective.
That does seems a bit like my 3.0R. It is about 102k miles old.
Absolutely, everyone's experience is different. If you think that video resembles comfortable suspension, the more power to you :p
I've heard this setup described as "butter smooth". Must be really lumpy butter where that poster came from ;)
Butter smooth? No, not in my opinion anyway. Comfortable? Yes for most of the roads I drive on. I'm not quite old enough to want Cadillac of yore ride quality.
Your video doesn't convey much as my eyeball and ear to ass converter seems to be broken.
:p
Then again, I came from DDing a 2100 lb 1991 Civic hatch with ploy LCA bushings, and Eibach revalved K&W V1 coilovers. I hear people describe the K&W setup for these cars as being incredibly smooth, but I am skeptical based on my experience with the Civic.
The best bet is to find someone with a suspension setup similar to what you are looking at and see if they will take you for a ride.
This combination seems marginally more comfortable than my crappy Megan Racing coilovers. Speed bumps and driveway entrances are about the only things that are better with the Bils and pinks.
I do have poly LCA bushings, but I didn't notice much of an increase in NVH when they went on.
