kaitanium Posted July 18, 2015 Share Posted July 18, 2015 Disconnected my battery (just (-) side to do some starter work and now my low hella horn doesnt sound. The high one sounds. Any ideas? All connections seem good, I even cleaned the contacts. Link to comment Share on other sites More sharing options...
NewLegGT67 Posted July 19, 2015 Share Posted July 19, 2015 I was having the same problem over the winter. I cleaned the female connectors with a wire brush and some WD40, which resolved the problem. I have mine mounted behind the grill so with all the snow and slush over the winter they were really dirty. I'm probably the only person that has Wu-Tang Clan and Paul McCartney on their mp3. Link to comment Share on other sites More sharing options...
kaitanium Posted July 20, 2015 Author Share Posted July 20, 2015 I may have to just clean mine but it makes really no sense that they would stop working after the battery disconnect! Turns out both horns arent functioning and only the 1x stock one i left on works. This is an easier situation to diagnose, sort of. Link to comment Share on other sites More sharing options...
freaksavior Posted July 21, 2015 Share Posted July 21, 2015 Check the fuse and relay? Link to comment Share on other sites More sharing options...
kaitanium Posted August 5, 2015 Author Share Posted August 5, 2015 tested the old relay and the leads, all seemed ok. Swapped out relay for the heck of it. Still dont work. Stock horn still works. Fuse looks good but I should check that with a multimeter too. Link to comment Share on other sites More sharing options...
