rfd425 Posted September 23, 2005 Share Posted September 23, 2005 For those of us who might consider retrofitting the USDM Spec B Bilstein suspension, what are the ramifications of the fact that the Spec B comes with 215/45/18 tires? Since those tires are a full inch taller (or a half-inch radius larger) than the regular 215/45/17 tires on the standard LGT, will the suspension parts fit properly? Excuse my ignorance. Link to comment Share on other sites More sharing options...
KGreb Posted September 23, 2005 Share Posted September 23, 2005 I'm running an imported set of Spec B Bilsteins, STi Pink springs, and Spec B wheels with 215/45/18 RE050s on a USDM LGT. No problems at all with fitment. Only ramification is that the speedo is probably reading about 5% off now. I've heard the dealer can correct this by reflashing the instrument cluster ECU. Link to comment Share on other sites More sharing options...
Tommyh Posted September 23, 2005 Share Posted September 23, 2005 This is something that i'd also like to find out about. I also wonder if this "upgrade" would bounce me out of the SCCA's stock class. Martin Luther - "Who loves not women, wine and song remains a fool his whole life long." EL4NFZT7 Link to comment Share on other sites More sharing options...
Qship Posted September 23, 2005 Share Posted September 23, 2005 "No problems at all with fitment" I'm really confused. I want to run a 215/50-17 on the stock rims. According to Xenok "25.5" might give you a clearance issue with the tire rubbing against the stock spring perch because the tire might be too tall." The Tirerack also says I can't run a 215/50-17. Are they mistaken? I calculate a 215/45/18, which KGreb is running, to have an overall diameter of 25.62 inches and a 215/50-17 to have an overall diameter of 25.46 inches. Is there a significant difference with the: Spec B Bilsteins, STi Pink springs, and Spec B wheels setup that avoids any fitment issues? Link to comment Share on other sites More sharing options...
KGreb Posted September 24, 2005 Share Posted September 24, 2005 All I know is that I have run two different suspension setups with the 215-45-18's and experienced no rubbing or other issues: - Spec B Bilsteins with Spec B springs (1/4" lower than USDM stock ride height) - Same as above but Pinks (3/4" lower than USDM stock ride height) I never ran this wheel/tire combo with the stock suspension. Given the similar ride height of the all Spec B setup, I'd suspect 215-45-18 would work ok with stock suspension. Link to comment Share on other sites More sharing options...
Zeus Posted September 25, 2005 Share Posted September 25, 2005 Has anyone priced this yet? I might do the full meal deal with the full suspension... Link to comment Share on other sites More sharing options...
