JoeJITSU Posted July 18, 2015 Share Posted July 18, 2015 My tuner was using OpenSource and he couldn't figure out why we only were able to get 13.8 psi on Boost. Please let me know if maybe the stock wastegate spring has a limit on boost or if there is a Map that would boost higher. Thank you Link to comment Share on other sites More sharing options...
whitrzac Posted July 18, 2015 Share Posted July 18, 2015 Is that peak, or at redline? Link to comment Share on other sites More sharing options...
JoeJITSU Posted July 18, 2015 Author Share Posted July 18, 2015 Is that peak, or at redline? Peak Link to comment Share on other sites More sharing options...
JoeJITSU Posted July 20, 2015 Author Share Posted July 20, 2015 what's stock suppose to be? Should I upgrade my Turbo, wastegate and Injectors? Link to comment Share on other sites More sharing options...
Redslaya Posted July 20, 2015 Share Posted July 20, 2015 stock peak wastegate pressure it 8PSI. stock peak power through the boost controller is 13.5psi Link to comment Share on other sites More sharing options...
gto7419 Posted July 24, 2015 Share Posted July 24, 2015 You should be able to only install a new turbo. Ircc, we, (obxt) got the tdo4 and you should be able to get a nice conservative tune on an lgt turbo or a vf52 without needing any other parts. On the other hand, you should def be able to pull more than 14 psi on that stock turbo. Tuner is doing something wrong or your car has issues. Link to comment Share on other sites More sharing options...
JoeJITSU Posted July 25, 2015 Author Share Posted July 25, 2015 He set it up for 19 but couldn't get anymore. Should we try AccessPort V3? Link to comment Share on other sites More sharing options...
JoeJITSU Posted July 25, 2015 Author Share Posted July 25, 2015 I smell an exhaust leak, not sure if this is holding back boost or not Link to comment Share on other sites More sharing options...
serx7 Posted July 27, 2015 Share Posted July 27, 2015 So your tuner's map is calling for 19 psi but you're only getting 13.8? Grab a Learning View or do a quick datalog @ idle to see what AF Learning #1A, B, C, D are. If those are substantially 'off', a leak could be the suspect. Your tuner is probably the preferred source of feedback/input, but do you have datalogs of any power pulls? Link to comment Share on other sites More sharing options...
gto7419 Posted July 28, 2015 Share Posted July 28, 2015 You could make 19psi on a td04 with an exhaust leak the size of Texas. Something else is going on... Link to comment Share on other sites More sharing options...
JoeJITSU Posted July 29, 2015 Author Share Posted July 29, 2015 You could make 19psi on a td04 with an exhaust leak the size of Texas. Something else is going on... Tuner thinks wastegate spring is holding it back Link to comment Share on other sites More sharing options...
gto7419 Posted July 30, 2015 Share Posted July 30, 2015 I don't think so, but a home depot helper spring on the wastegates arm will let you know rather quickly if that's your issue.... Link to comment Share on other sites More sharing options...
