edek Posted July 12, 2015 Share Posted July 12, 2015 Hi, i own a1994 legacy without O2 sensor....now i bought an new exaust that have that sensor......is convenient to atach it...? wich is the wire for that....had 94 models this sensors ?? Thanks in advance Edek -from Patagonia !!- Link to comment Share on other sites More sharing options...
GTEASER Posted July 14, 2015 Share Posted July 14, 2015 Is the original harness connector located somewhere near the O2 sensor on the exhaust? GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
edek Posted July 15, 2015 Author Share Posted July 15, 2015 Hi thanks for your interest ! the only wire terminal i see is the one comming from the same location of the backlight conection to the gearbox.....i don´t know if it is ox sensor or neutral switch...also may be other gearbox item... Link to comment Share on other sites More sharing options...
GTEASER Posted July 15, 2015 Share Posted July 15, 2015 It would be helpful if you could tell me what color the wires are at the connector. If they are Black/White, Yellow/Red and White, then that is the O2 sensor connector. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
edek Posted July 16, 2015 Author Share Posted July 16, 2015 Ok, as soon as i can i´ll take a look at that....Thanks a lot !! Link to comment Share on other sites More sharing options...
edek Posted July 29, 2015 Author Share Posted July 29, 2015 Hi. here i am again.....the wires on the conector are three....one white other black and the third is a yellow blue and black miscelaneous..... it sounds strange that three wires for the sensor.... Link to comment Share on other sites More sharing options...
GTEASER Posted July 29, 2015 Share Posted July 29, 2015 You should go to bbs.legacycentral.org and download the service manuals with wiring diagrams. Yes, the O2 sensor is a 3-wire setup. Can you post some pics of where you found this connector and what it looks like? GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
edek Posted July 30, 2015 Author Share Posted July 30, 2015 Hi, here are some photos of the terminl and wires........ Link to comment Share on other sites More sharing options...
GTEASER Posted July 30, 2015 Share Posted July 30, 2015 Yes, that's the O2 sensor harness connector. Those wires are yellow/red, black/white and white. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
edek Posted July 30, 2015 Author Share Posted July 30, 2015 Thanks !! i have this car since last october and never had an oxigen sensor at all...neither a place to fit it...!! may be normal ??...now i have a new stailess steel complete exhaust (not yet installed) that has a place for the sensor... Link to comment Share on other sites More sharing options...
GTEASER Posted July 30, 2015 Share Posted July 30, 2015 Once you install the sensor, make sure to disconnect the battery for 10 minutes to reset the ECU. It should run better and get better gas mileage with the O2 sensor installed. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
edek Posted July 31, 2015 Author Share Posted July 31, 2015 ok, i´ll do that as soon as possible....i´m fighting with a knock wich don´t know if is comming from rod, or is a piston slap.... Link to comment Share on other sites More sharing options...
