goldbhgt Posted July 11, 2015 Share Posted July 11, 2015 hoping i have this in the correct section. i have a 2000 legacy gt wagon, 175,xxx miles that i purchased about a month ago. its my first subaru, so forgive me as i'm a bit of a noob to them. head gasket and clutch were done about 50k miles ago, so i know it will be due for them again in the future. i have already had a few issues with it. issue 1) i went for a drive about two weeks after having the car on a pretty good turny (is that a word?) and hilly road (route 26 out of marietta, ohio for anyone who may know), when i noticed that taking some turns, the temp would raise to max and then would fall back to normal on straights. it would do the same after climbing a hill, and then id let it coast in neutral and it would fall back to normal temps. after i got out of the hills and back on to the road that followed the ohio river that stayed flat, everything was fine. issue 2) yesterday going about 60 mph, i noticed a slight shake in the steering wheel that gets worse the faster i go, and when i turn to the right at these speeds (interstate type turns, not tight) there is a noise that i can't really describe. its like a grinding/thumping sound. i pulled over and checked everything out, didn't see anything odd, so i went on my way and it never happened again. then today it happened in the same stretch of road, the exact same thing happened. except this time i've noticed it a few other times away from where i originally noticed it. everything seems to be tight, but i haven't had a chance to lift it and check everything out. any help as to what could be causing these issues would be great and much appreciated! Link to comment Share on other sites More sharing options...
