Ironcheflove Posted July 8, 2015 Share Posted July 8, 2015 I was looking to replace my radiator as it's seen better days. I've got a 1997 Legacy Wagon 2.2L A/T L. Will I be able to mount a 2nd Gen OB rad without any mods? Link to comment Share on other sites More sharing options...
johnegg Posted July 8, 2015 Share Posted July 8, 2015 I've got a 1997 Legacy Wagon 2.2L A/T L. Will I be able to mount a 2nd Gen OB rad without any mods? 96 - 99 outback yes. as long as you have the outback top and bottom brackets. the lego brackets are different. 00 - 04 outback , NO. typically, when you buy a NEW radiator it does not come with the brackets. if you are buying used then you should be good as long as the rad is not stripped. and of course the outback rad must be from an auto trans car. Link to comment Share on other sites More sharing options...
Ironcheflove Posted July 12, 2015 Author Share Posted July 12, 2015 OK, thank you John. I was able to find a 2-row for my Legacy. Should be here in a few days and hopefully it'll solve my overheating while pulling a hill or with the A/C running in 100+ weather... Link to comment Share on other sites More sharing options...
