OB radiator in Legacy?
I've got a 1997 Legacy Wagon 2.2L A/T L. Will I be able to mount a 2nd Gen OB rad without any mods?
96 - 99 outback yes.
as long as you have the outback top and bottom brackets.
the lego brackets are different.
00 - 04 outback , NO.
typically, when you buy a NEW radiator it does not come with the brackets.
if you are buying used then you should be good as long as the rad is not stripped.
and of course the outback rad must be from an auto trans car.
