Jdubgt530 Posted July 6, 2015 Share Posted July 6, 2015 I'm going to be doing my head gaskets this week, just want some opinions on what else I should do while my heads are off. Here's all the parts I have. 1.headgasket set 2.new radiator 3.new timing belt component kit w/ water pump 4.new upper and lower radiator hoses. Link to comment Share on other sites More sharing options...
monkeyposeur Posted July 6, 2015 Share Posted July 6, 2015 Replace all your coolant and vacumm lines (yours are old and might bite you in the ass later, easier to replace now), pcv valve, reseal oil pump and replace oil pump o ring, cam seals, crank seal, intake manifold gasket, clean your iacv and replace gasket, new knock sensor, spark plugs and plug wires, fuel filter, valve cover gaskets, oil filler neck o ring. Clean throttle body. Link to comment Share on other sites More sharing options...
DGR81 Posted July 6, 2015 Share Posted July 6, 2015 Don't forget the thermostat Link to comment Share on other sites More sharing options...
bjkroll Posted July 11, 2015 Share Posted July 11, 2015 Sounds like you're pulling the motor. Don't forget the oil separator plate! Good source of an oil leak, and its fairly cheap from the dealership. Link to comment Share on other sites More sharing options...
