kelseyrgoff95 Posted June 30, 2015 Share Posted June 30, 2015 About a week ago my 06 legacy had a cylinder 4 misfire code and would jerk badly when I came to a stop and tried to take off again. We change the spark plug and put sea foam brand injector cleaner in it, that fixed it for about 2 days with little driving but today I had to go on a farther drive and it started doing the exact same thing. any help or advise would be greatly appreciated! Link to comment Share on other sites More sharing options...
BossCock Posted June 30, 2015 Share Posted June 30, 2015 Did you replace just the plug? Or did you do the wire as well? I had some misfire issues on cylinder 3 and a new plug + wire fixed the problem. If you have a psev and live in a CA emissions state, you can get that covered by the dealer under the emissions warranty. Link to comment Share on other sites More sharing options...
kelseyrgoff95 Posted June 30, 2015 Author Share Posted June 30, 2015 I did not replace the wire, I will try that thank you! And unfortunately the place I bought it from is just a lousy second hand dealer spot that sold it to me with existing problems so they would be no help. Link to comment Share on other sites More sharing options...
BossCock Posted June 30, 2015 Share Posted June 30, 2015 Just looked into and WV isn't CA emissions anyways. If it was, SOA would cover the costs of replacement if you went to the Subaru dealer. Let us know if replacing the wire helps! Link to comment Share on other sites More sharing options...
