housemusic1 Posted November 30, 2015 Share Posted November 30, 2015 Nope. S techs sit on the bumpstops in front, or nearly on them, from what I can gather. that's why they are as low as you can go. And any "settling" is the bump stops disintegrating from constant smashing. In front at least. Yeah, just wondering why you went with H Techs. I think the most popular combo is Koni/Swift, but I've heard that they are stiff. Link to comment Share on other sites More sharing options...
Tuning Alliance Posted November 30, 2015 Share Posted November 30, 2015 Black with black wheels, looks great! Contact us for all your tuning and performance parts needs! Etuning the legacy community since 2008! Follow us on FACEBOOK | INSTAGRAM [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
rebourne Posted November 30, 2015 Author Share Posted November 30, 2015 Yeah, just wondering why you went with H Techs. I think the most popular combo is Koni/Swift, but I've heard that they are stiff. I was looking for something just about an inch lower than the lgt springs. Not 1.5", not 1.4", just 1.0". Hard to find. Then saw the h tech's pop up on Amazon for well under $200 and figured I'd try them. Would be an easy resale if i didn't like them. So while I'd like the front to be a bit lower appearance-wise, i think the h tech's are the perfect compromise. Took a friend out in my obxt that had Koni/epics, and he said my set up rides better. pic thread build thread Link to comment Share on other sites More sharing options...
housemusic1 Posted November 30, 2015 Share Posted November 30, 2015 I figured it out.... Add an eBay s204 lip, and give the appearance of being a little lower! Link to comment Share on other sites More sharing options...
rebourne Posted December 1, 2015 Author Share Posted December 1, 2015 I figured it out.... Add an eBay s204 lip, and give the appearance of being a little lower! I do really like that idea. I'll look into it once I get the small stash of parts I have installed. GS intake, TMIC, the Perrin steering elbow clamp thingy, LGT ABS sensor, DW fuel pump, and I'm probably forgetting some things... pic thread build thread Link to comment Share on other sites More sharing options...
jonnyt88 Posted December 5, 2015 Share Posted December 5, 2015 Ive noticed a lot of OBXT owners will run an 18" with 45 profile tire. What made you decide to run with a 40? The H-techs's done seem super low like some... actually its a quite perfect stance. Link to comment Share on other sites More sharing options...
rebourne Posted December 5, 2015 Author Share Posted December 5, 2015 Ive noticed a lot of OBXT owners will run an 18" with 45 profile tire. What made you decide to run with a 40? The H-techs's done seem super low like some... actually its a quite perfect stance. Assuming you mean, don't seem super low? Thanks! It's a great balance. Why 40s? Luck of the draw. The Enkie's came up on CraigsList with a good quality tire at a fantastic price. Not some low end junk tire. Figured if I could get them, I'd give it a try. It's is lower profile and diameter than I had considered running. To be near perfect fitment with my camber settings, the 18x8 Enkies would be about a +30 or even +25 (they are +40). 8.5 wide and +30 might be just perfect, and run a bit wider tire. And for total diameter, about half way between LGT and OBXT looks like the sweet spot on paper. Looking at the pics in "Thomistopheles' 06 OBXT" build thread, http://legacygt.com/forums/showthread.php/thomistopheles-06-obxt-limited-baller-husky-hauler-iii-247594.html, I'm going to keep my eye out for some 17 x 8 to 9s. Something about his I like, but with a bit smaller diameter tire (yet taller than mine). A 17x9 +35 with a 245/45/17 might be perfection. pic thread build thread Link to comment Share on other sites More sharing options...
housemusic1 Posted December 7, 2015 Share Posted December 7, 2015 Just wondering, what is the benefit of the Legacy rear upper control arms for a lowered Outback? Link to comment Share on other sites More sharing options...
Rhitter Posted December 7, 2015 Share Posted December 7, 2015 Just wondering, what is the benefit of the Legacy rear upper control arms for a lowered Outback? You get about an inch more travel by switching them out. Outback is on top, legacy on bottom. http://i.imgur.com/rn5Z3PV.jpg?1 My OBXT build Link to comment Share on other sites More sharing options...
housemusic1 Posted December 7, 2015 Share Posted December 7, 2015 You get about an inch more travel by switching them out. Outback is on top, legacy on bottom. http://i.imgur.com/rn5Z3PV.jpg?1 Aha, I see. Well, I guess if I'm doing all new suspension, it wouldn't hurt to go with different lower control arms. Thanks for the info. I think I was getting confused with some other rear suspension components. Link to comment Share on other sites More sharing options...
rebourne Posted December 7, 2015 Author Share Posted December 7, 2015 Yeah, what he said. However! If you are going with coil overs, like BC etc, they have bump stops in the rear shocks (right? uh, please verify first... I read this somewhere), so you can just unthread the rear OBXT rubber helper bumpstop thingy and be done. Then you'll adjust the pre-load, springy thingy stuff of the coil over to be your bump stop and control your travel. Might be a waste to install the LGT arms. pic thread build thread Link to comment Share on other sites More sharing options...
housemusic1 Posted December 7, 2015 Share Posted December 7, 2015 Yeah, what he said. However! If you are going with coil overs, like BC etc, they have bump stops in the rear shocks (right? uh, please verify first... I read this somewhere), so you can just unthread the rear OBXT rubber helper bumpstop thingy and be done. Then you'll adjust the pre-load, springy thingy stuff of the coil over to be your bump stop and control your travel. Might be a waste to install the LGT arms. I'm going the Koni route. Currently on LGT suspension, with Legacy bump stops. Going a bit lower, just not sure of rear control arms are necessary, or more of a comfort thing? Link to comment Share on other sites More sharing options...
rebourne Posted December 7, 2015 Author Share Posted December 7, 2015 I'd get them, then. It will help ride for sure. Gives the rear shocks and springs more travel to do their thing before the rubber bumpers say party over. pic thread build thread Link to comment Share on other sites More sharing options...
housemusic1 Posted December 7, 2015 Share Posted December 7, 2015 (edited) I'd get them, then. It will help ride for sure. Gives the rear shocks and springs more travel to do their thing before the rubber bumpers say party over. OK. Thanks. How about the rear lower control arms? Swap over to Legacy as well? Edited December 7, 2015 by housemusic1 Link to comment Share on other sites More sharing options...
rebourne Posted January 20, 2016 Author Share Posted January 20, 2016 OK. Thanks. How about the rear lower control arms? Swap over to Legacy as well? No need to as far as I know. pic thread build thread Link to comment Share on other sites More sharing options...
rebourne Posted June 17, 2016 Author Share Posted June 17, 2016 pic thread build thread Link to comment Share on other sites More sharing options...
rebourne Posted July 4, 2016 Author Share Posted July 4, 2016 New Camera, Panasonic GX85. +borrowed 15mm 1.7 lens. +Clean car. = Photo op. pic thread build thread Link to comment Share on other sites More sharing options...
rebourne Posted August 17, 2016 Author Share Posted August 17, 2016 I'm trying to keep the tech to the "build" thread: http://legacygt.com/forums/showthread.php/rebournes-06-obxt-build-thread-243318.html and this one just pretty pictures. Gonna quote it from here and respond in the build thread: http://legacygt.com/forums/showthread.php/rebournes-06-obxt-build-thread-243318.html?p=5462564#post5462564 pic thread build thread Link to comment Share on other sites More sharing options...
rebourne Posted October 21, 2016 Author Share Posted October 21, 2016 pic thread build thread Link to comment Share on other sites More sharing options...
rebourne Posted June 23, 2017 Author Share Posted June 23, 2017 (edited) Sitting on stocks tires/wheels while waiting for new tires for the 18" Imolas. edit: I played around with the white balance, using the eye dropper tool, etc... and in the end I think this is right. The sun was going down, everything was all glowing warm orange and reds... It's right for the time of day. Edited June 23, 2017 by rebourne pic thread build thread Link to comment Share on other sites More sharing options...
rebourne Posted July 6, 2017 Author Share Posted July 6, 2017 goofing off with the phone camera: Purposely trying to get the lens halos and sun streaks: pic thread build thread Link to comment Share on other sites More sharing options...
Nightmaresmk Posted July 7, 2017 Share Posted July 7, 2017 Holy ass squat batman LMAO Link to comment Share on other sites More sharing options...
rebourne Posted July 7, 2017 Author Share Posted July 7, 2017 (edited) Holy ass squat batman LMAO I think it's just the camera angle and the way it's on the downward angle towards the street. Flip the car around and move it forward: Look better this way, or still too saggy? I think it could use another 3/8" higher in the rear. That would be a 3/4" total rear spacer, versus the 3/8" that's in there now. Edited July 7, 2017 by rebourne pic thread build thread Link to comment Share on other sites More sharing options...
housemusic1 Posted July 7, 2017 Share Posted July 7, 2017 Looks like she's loaded down in the rear. 3/4" spacer would level her out. Link to comment Share on other sites More sharing options...
rebourne Posted July 10, 2017 Author Share Posted July 10, 2017 hopefully this is the last pic of it with the oem wheels for a while: pic thread build thread Link to comment Share on other sites More sharing options...
