bugblatterbeast Posted June 27, 2015 Share Posted June 27, 2015 I pulled my intake manifold and TGVs out to remove a mouse nest and replace the turbo inlet tube. After pulling it I found that the passenger side gasket between the head and TGV assembly was leaking. For the guys running higher than stock boost, what gasket has proven to be reliable here. I'm running 22-23 psi. I was also wondering if anyone knows if the 04-06 sti uses the same fuel rails as the 05 LGT? I have to replace one fuel rail due to corrosion. I found a cheap used set for the sti. Link to comment Share on other sites More sharing options...
