BadBrew Posted June 27, 2015 Share Posted June 27, 2015 I've read in another thread that we only need to connect any device to the RCA jack and press the INFO button to switch to this auxiliary video input. I hooked up a small DVD player but the info button only switch to the car settings as usual. I am not using the molex connector for the backup cam at this point. What am i doing wrong? Thanks! Link to comment Share on other sites More sharing options...
apexi Posted June 27, 2015 Share Posted June 27, 2015 I'm still reading though the thread below, which might be the thread you have also seen. http://legacygt.com/forums/showthread.php/another-oem-navi-features-hack-thread-progress-and-documents-36342p2.html? I read one reply where someone mentions that the device must be connected to the nav when unit is booting up. It sounds like he's using the molex connector, but it's worth trying that with the rca jack as well. *Still reading, one more idea is to try hitting the info button twice. Link to comment Share on other sites More sharing options...
apexi Posted June 27, 2015 Share Posted June 27, 2015 One more quote from that thread It's pretty easy, you either have to remove the stereo or the screen, I had the stereo out when I did it and I just reached behind the screen, felt the input and plugged an RC cable into it. I ran that under the center console and and popped it out on the side to go under the passenger seat like Windy Road did. once it's plugged in you just hit the info button twice and it'll switch to the RCA. The parking brake needs to be up at that point, but if you remove the nav screen you can ground the parking sensor wire and it'll work at all times, even when the car is in motion. Link to comment Share on other sites More sharing options...
BadBrew Posted June 27, 2015 Author Share Posted June 27, 2015 One more quote from that thread Yep that's the part I missed in that thread, pulled braking brake, double tap info and got the DVD working. This adds whole bunch of awesomeness for me while waiting between calls on the road! Thanks apexi! Link to comment Share on other sites More sharing options...
