Delakor Posted June 21, 2015 Share Posted June 21, 2015 Does my Subaru EJ20G engine knock or is it the valves? The sound comes and goes. With the knock https://www.youtube.com/watch?v=86ZDkWkIlaY Without the knock https://www.youtube.com/watch?v=Nlszqf_g4f4 Link to comment Share on other sites More sharing options...
bcmaxx Posted June 22, 2015 Share Posted June 22, 2015 Mine makes a similar noise. Im tearing it down this week Link to comment Share on other sites More sharing options...
USLiberty Posted June 22, 2015 Share Posted June 22, 2015 It's a common valve lifter noise for the ej20g, inherent with the "rocker arm" heads. It's like an air bubble in the hydralic buckets. No adjustment available or parts. You can try taking apart and cleaning but it didnt work for me. I took my camshaft apart and found the buckets to be clean. I talked to John at Outfront Motorsports who knows these motors very well and he said it's not effecting the longevity,operation of the motor and its just annoying. My 80kmile motor made it and I ran mystery oil for a few 1000 miles, changed oil to shell rotella t6 and the noise started to go away after warm-up. Finding parts for those heads is hard and if you really want the noise to go away, install better heads on it. http://i1065.photobucket.com/albums/u386/onefastlt/P2280846_zpsp1vzzejl.jpg Link to comment Share on other sites More sharing options...
Delakor Posted June 23, 2015 Author Share Posted June 23, 2015 It's a common valve lifter noise for the ej20g, inherent with the "rocker arm" heads. It's like an air bubble in the hydralic buckets. No adjustment available or parts. You can try taking apart and cleaning but it didnt work for me. I took my camshaft apart and found the buckets to be clean. I talked to John at Outfront Motorsports who knows these motors very well and he said it's not effecting the longevity,operation of the motor and its just annoying. My 80kmile motor made it and I ran mystery oil for a few 1000 miles, changed oil to shell rotella t6 and the noise started to go away after warm-up. Finding parts for those heads is hard and if you really want the noise to go away, install better heads on it. http://i1065.photobucket.com/albums/u386/onefastlt/P2280846_zpsp1vzzejl.jpg Just took it to a mechanic and he said the same thing as you, but it's very annoying yes. But I'm going to try to get 300 bhp out of the engine after my rebuild, so I'm thinking a new head would do good! What head would you suggest? Something that is bolt on, or nearly bolt on is always great <3 Link to comment Share on other sites More sharing options...
USLiberty Posted June 24, 2015 Share Posted June 24, 2015 Jdm Ej20k or non-avcs us-wrx heads should work better. However the ej20g pistons come out past the deck so you may need an extra thick gasket. I had a RSlibertyclub.org membership but they must of figured out I was American and I got banned without being able to post an introduction. Link to comment Share on other sites More sharing options...
Delakor Posted June 25, 2015 Author Share Posted June 25, 2015 What are your thoughts on a upgraded oil pump for future horsepower inscrease and a better supply of oil to the engine. Like this one for example http://www.maperformance.com/orbit-high-performance-oil-pump-subaru-ej20-ej22-ej25-opsb1478hp.html or if there are any better ones, feel free to link them :-) Link to comment Share on other sites More sharing options...
monkeyposeur Posted June 26, 2015 Share Posted June 26, 2015 Don't use anything other than an OEM 10mm oil pump designed for the 22T. It is perfectly sufficient and your engine doesn't require any more flow. Search NASIOC if you want more specific information on the subject. If you had dual AVCS or looser bearing clearances than you could get away with it. Link to comment Share on other sites More sharing options...
bcmaxx Posted June 26, 2015 Share Posted June 26, 2015 supercedes to a 15010aa300 sti pump Link to comment Share on other sites More sharing options...
USLiberty Posted June 28, 2015 Share Posted June 28, 2015 OEM only! Link to comment Share on other sites More sharing options...
