90legl Posted June 20, 2015 Share Posted June 20, 2015 hi guys my name is trevor dean im from the united states i just picked up a 1990 legacy wagon l awd! im completely in love with it even for its age. but i want more. i know a version of the first generation legacy the legacy rs was a turbo model. i was wonder what the specific motor code to that motor is and a few other things 1. will my cross member be compatible with the new motor? 2. what the name of the turbo motor is i know i have the ej22 at the moment. 3 will my engine loom work with the the turbo ecu and turbo motor? 4. what else will i need beside the motor ecu and few other things to make it work. any help will be more than appreciated and i am mechanically inclined thank you all and hope to get this build on the road asap! Link to comment Share on other sites More sharing options...
USLiberty Posted June 22, 2015 Share Posted June 22, 2015 The liberty rs motor was an ej20g. You will need a turbo crossmember or the balls to cut the n/a crossmember to make room for the turbo uppipe. I think you need a turbo ecu and harness to make it run correctly. I went with a standalone/wire in ecu. Link to comment Share on other sites More sharing options...
GTEASER Posted June 24, 2015 Share Posted June 24, 2015 I would suggest you spend some time both here and over on bbs.legacycentral.org reading and researching. What you are trying to do is not impossible, but also not simple. Do you research BEFORE buying stuff. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
bcmaxx Posted June 24, 2015 Share Posted June 24, 2015 I did this swap using a 2.2t engine, sti turbo and wrx intercooler, stock na ecu, holley -variable ratio via bleed port- fmu ( i wouldnt use or trust any other), 255lph pump, meth injection, and aem wideband. I can tune without detonation up to 20 psi, and run 13-15psi daily. would I do it again??? nope. i would do a turbo ecu or a newer ecu with a harness merge. 1- notch the xmemeber, or replace with a turbo crossmember, (I think a company "subachad" makes an uppipe to clear the x member. 2- my engine is stamped ej22b but its refered to as ej22t 3- get all the underhood wiring if you can off the turbo car, including solenoids, and pressure sensors, and you will have to run a few sheilded wires directly to the ecu, as well as swap the cam and crank pins, or reverse the terminals. 4- you will need a downpipe, a GOOD true wideband air/fuel ratio meter ( not a fake autometer pos) ,and you will need much more time than you had expected. having said all that you will have a kickass lil car after! If you have any specific questions just msg me! my beginning:http://i232.photobucket.com/albums/ee110/bcmaxx/wbeaterr_zps1457e0cf.jpg http://i232.photobucket.com/albums/ee110/bcmaxx/20150603_202627_zpso3l88ook.jpg http://i232.photobucket.com/albums/ee110/bcmaxx/20150519_082543_zpsxnerkpqs.jpg Link to comment Share on other sites More sharing options...
90legl Posted June 30, 2015 Author Share Posted June 30, 2015 so the subachad uppipe is meant to clear the n/a crossmember? Link to comment Share on other sites More sharing options...
90legl Posted June 30, 2015 Author Share Posted June 30, 2015 that looks like alot of extra work for the subachad one i want to keep as much stock tubular piping as i can so ill just get the turbo crossmember Link to comment Share on other sites More sharing options...
bcmaxx Posted June 30, 2015 Share Posted June 30, 2015 I notched mine with a plasma cutter. to keep stock stuff. so everything lines up like it should. fit is perfect uses stock wrx brackets Link to comment Share on other sites More sharing options...
90legl Posted July 18, 2015 Author Share Posted July 18, 2015 do you think you could take a picture of the knotching your talking about? Link to comment Share on other sites More sharing options...
bcmaxx Posted July 20, 2015 Share Posted July 20, 2015 Sure can the engine is out right now. Ill snap a pic later Link to comment Share on other sites More sharing options...
bcmaxx Posted July 21, 2015 Share Posted July 21, 2015 http://i232.photobucket.com/albums/ee110/bcmaxx/20150630_212402_zpslc7fgs8h.jpg Link to comment Share on other sites More sharing options...
90legl Posted August 10, 2015 Author Share Posted August 10, 2015 I guess more of my question is if I switch ecu engine harness and transmission harness will all my in cabin wiring work with the obd1 turbo ecu I am purchasing? Link to comment Share on other sites More sharing options...
bcmaxx Posted August 11, 2015 Share Posted August 11, 2015 Yes. Link to comment Share on other sites More sharing options...
90legl Posted August 12, 2015 Author Share Posted August 12, 2015 even if i go from ej22e to an ej20g? Link to comment Share on other sites More sharing options...
90legl Posted August 12, 2015 Author Share Posted August 12, 2015 this what im buyingg motor wise ive had multiple friends go through this site and had exellent things to say all around. http://www.jdmenginedepot.com/jdm_engine_details/188/ej20g-impreza-wrx-turbo-gc8-493-jdm-ej20g Link to comment Share on other sites More sharing options...
bcmaxx Posted August 12, 2015 Share Posted August 12, 2015 even if i go from ej22e to an ej20g? yeah i'm not too sure about that, Im sure wire by wire it can be merged, hopefully theres some gurus on here that have some knowledge. Link to comment Share on other sites More sharing options...
90legl Posted August 12, 2015 Author Share Posted August 12, 2015 because i cant find an ej22t for sale anywhere Link to comment Share on other sites More sharing options...
GTEASER Posted August 12, 2015 Share Posted August 12, 2015 there is one for sale on bbs.legacycentral.org and a guy in Kentucky has one for sale on the 1st/2nd Gen Legacy FB group. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
90legl Posted August 13, 2015 Author Share Posted August 13, 2015 bc maxx i did not mean to delete your comment thank you for the direction immenslt Link to comment Share on other sites More sharing options...
90legl Posted August 13, 2015 Author Share Posted August 13, 2015 Talked to a Subaru tech that works for mttechsubaru and he said the pigtails of the in cab wiring would work with any od1 Subaru ecu turbo/non turbo so excited Link to comment Share on other sites More sharing options...
90legl Posted August 24, 2015 Author Share Posted August 24, 2015 So I've come to the conclusion I will never have a ej22t and may just buy an ej20g and run my trans and rear diff into the ground until I get LSD and 6mt. Only question I have is if I Chang ecus to the ej20 ecu if I'll have to have the harness merged professionaly or not because **** wiring. Hopefully I can just use the ej22 in cab harness with ej20t ecu. Link to comment Share on other sites More sharing options...
wtdash Posted August 26, 2015 Share Posted August 26, 2015 Hi "Only Question" :-) Please spend some time Searching over on Legacy Central. The EJ20G/T, EJ22T and EJ22e OBD1 ECUs are ALL very similar in their wiring. See THIS. Also, I've covered the wiring changes w/my post HERE and HERE between EJ22T and EJ22 and EJ20G. TD Link to comment Share on other sites More sharing options...
90legl Posted August 31, 2015 Author Share Posted August 31, 2015 I'm buying a modded ej20g harness to work with my 22t harness Link to comment Share on other sites More sharing options...
90legl Posted August 31, 2015 Author Share Posted August 31, 2015 Meant ej22t ecu not 22t harness Link to comment Share on other sites More sharing options...
