jon450 Posted June 16, 2015 Share Posted June 16, 2015 Hi Got an issue with the climate control on my legacy. It don't work lol I've tried the normal stuff gas is ok relays are ok fuse ok etc. you cannot read it from the obd port. After some searching I found that you can read it from the display inside by holding the air recirc and auto button on together then turn on the ignition. It lights the panel up and the display flashes, then it displays 20. I am assuming the is a fault code. As with other models it is. Does anyone know if this is a fault code and what it is. The car is a legacy diesel 2009 Thx Jon Link to comment Share on other sites More sharing options...
apexi Posted June 17, 2015 Share Posted June 17, 2015 It looks like "20" means there is no fault. Link to comment Share on other sites More sharing options...
jon450 Posted June 29, 2015 Author Share Posted June 29, 2015 Thx for that, still trying to get it working Link to comment Share on other sites More sharing options...
