bjkroll Posted June 14, 2015 Share Posted June 14, 2015 Hey guys, So I noticed a difference in ignition coils on the earlier 2.5L NA ignition coil vs. the later versions. Specifically, they use a DIN connector attached to the coil itself, and the mating connection for the plugs are female. Do they produce a different spark? Is the only difference the type of connection? I'm curious if I could get away with splitting the cable and attaching the later version of ignition coil, along with the matching wires. The reason being is I feel the ignition coil is starting to fail. During very humid conditions, I get a misfire on cyl. 3. I have a spare ignition coil that I wanted to try, but its the later model. What I have on the car: http://www.rockauto.com/info/457/VE520418__ra_p.jpg What I wanted to try: http://www.rockauto.com/info/154/UF193photo%20primary__ra_p.jpg Link to comment Share on other sites More sharing options...
bjkroll Posted June 14, 2015 Author Share Posted June 14, 2015 Geez, not to mention the $70 difference in price on Rock Auto! Link to comment Share on other sites More sharing options...
twisty Posted June 15, 2015 Share Posted June 15, 2015 the MSD coil upgrade is from a early 2000s dodge neon and it works well. this one is a subaru part for a newer gen engine of the same family, im betting if you can make it fit, it will work. Link to comment Share on other sites More sharing options...
