DylanGC Posted June 11, 2015 Share Posted June 11, 2015 Hi, I am looking at replacing the bypass valve on my JDM GT Twin scroll, MY06. I am not sure if the GFB T9001 will fit as after removing the OEM valve, I note that the opening is a diamond shape as in the below image. But the base of the GFB T9001 has a round opening, it is also supplied with a gasket with a round opening. See images below. I know it will bolt on, but will it leak due to the larger opening than hole on the GFB T9001? Thanks Link to comment Share on other sites More sharing options...
Streetlegal Posted June 11, 2015 Share Posted June 11, 2015 I have the same one on mine. Fits without and issue and it doesn't leak. Link to comment Share on other sites More sharing options...
DylanGC Posted June 11, 2015 Author Share Posted June 11, 2015 Excellent, thanks for the info! Off to order one now Link to comment Share on other sites More sharing options...
