I Cannot Play Bass Posted May 24, 2015 Posted May 24, 2015 I am looking for a local pick up on these, because I want the buyer to see exactly what they are getting. I ordered them from the east coast and was really bummed out when they arrived flaking and showing surface rust. They were clearly part of the production run that was transported before being powder coated. However, given how hard it is to come across a rear bar, I cleaned it up, Plastidipped it, and ran it for 2.5 years on the stiff setting without an issue. I am looking for $350 for the Kartboy end links, Whiteline bushings, 25mm rear bar, 22 mm front bar, and COBB rear mount support brackets. The bushings were moved out of their normal seating to show the wear on the bars below: http://i222.photobucket.com/albums/dd183/ICannotPlayBass/COBB%20Sway%20Bars/DSCN0743.jpg http://i222.photobucket.com/albums/dd183/ICannotPlayBass/COBB%20Sway%20Bars/DSCN0744.jpg http://i222.photobucket.com/albums/dd183/ICannotPlayBass/COBB%20Sway%20Bars/DSCN0745.jpg http://i222.photobucket.com/albums/dd183/ICannotPlayBass/COBB%20Sway%20Bars/DSCN0746.jpg http://i222.photobucket.com/albums/dd183/ICannotPlayBass/COBB%20Sway%20Bars/DSCN0747.jpg http://i222.photobucket.com/albums/dd183/ICannotPlayBass/COBB%20Sway%20Bars/DSCN0748.jpg http://i222.photobucket.com/albums/dd183/ICannotPlayBass/COBB%20Sway%20Bars/DSCN0749.jpg http://i222.photobucket.com/albums/dd183/ICannotPlayBass/COBB%20Sway%20Bars/DSCN0750.jpg http://i222.photobucket.com/albums/dd183/ICannotPlayBass/COBB%20Sway%20Bars/DSCN0751.jpg
scoobyscoodle Posted May 28, 2015 Posted May 28, 2015 Is it just me, or does the blue one look 25mm and the black(rear) one look like 22mm?
I Cannot Play Bass Posted May 30, 2015 Author Posted May 30, 2015 Is it just me, or does the blue one look 25mm and the black(rear) one look like 22mm? Thank you. You are absolutely correct, the Cobb and Hotckis sets are 25mm up front and 22 mm in the rear.
schuylern Posted August 1, 2015 Posted August 1, 2015 Do you still have these? Sent from my Nexus 6 using Tapatalk
I Cannot Play Bass Posted August 4, 2015 Author Posted August 4, 2015 Do you still have these? These have been sold.
rebourne Posted August 4, 2015 Posted August 4, 2015 These have been sold. Can you edit the title of of your original post to say "Sold"? You can edit the title in the Advanced mode of the edit window. pic thread build thread
I Cannot Play Bass Posted August 18, 2015 Author Posted August 18, 2015 Can you edit the title of of your original post to say "Sold"? You can edit the title in the Advanced mode of the edit window. Doneskies.
