Timmonsbm33 Posted May 16, 2015 Share Posted May 16, 2015 I have a 2005 LGT 5MT with about 111K miles on it. As of about a month ago i upgraded to stage 1, Cobb intake and OTS Stage 1+ SF intake map. Over the past weeks i have noticed the engine revving quickly when gas is applied even though there is not a increase in speed. It does it even when increasing speed via the cruise control. I have no problem going from a dead stop, only when i apply gas at speed in any gear. So my question is, is my clutch going out? If not then what is? What are the best parts to replace this? I have access to a complete garage and plan on doing the work my self and hopefuly soon going to a stage 2 setup (might do that at the same time as i have to pull out the exhaust) More details about the car, I am the second owner, had it for about 5 years. Of that five years it has been in storage about 30 months as i am military and been busy. Recently i have replaced the rear diff and tranny fluid with Mobile 1 Synthetic 75w-90, and had the passenger side front CV axle replaced. THe car is my daily driver, most my trips are on base and less than 4 miles. To the office from the barracks, to the chow hall, gym, store, etc.... Thanks for you help. Link to comment Share on other sites More sharing options...
travrach Posted May 16, 2015 Share Posted May 16, 2015 Sure sounds like the clutch is slipping. A clutch kit will have what's needed, you can also do the rear main seal while at it. Link to comment Share on other sites More sharing options...
Timmonsbm33 Posted May 16, 2015 Author Share Posted May 16, 2015 What about a fly wheel, throw out bearing, etc... Sorry i am not very knowledgeable about transmissions and clutches. Link to comment Share on other sites More sharing options...
travrach Posted May 16, 2015 Share Posted May 16, 2015 Great point, throw out should come in the kit. You can either get your flywheel machined or buy a new one. Others may have another idea.. Link to comment Share on other sites More sharing options...
