justin303films Posted May 12, 2015 Share Posted May 12, 2015 Hey guys looking to pick up a set of OZ Supperleggera wheels tomorrow 18x8 and wondering if they are going to rub or have fitment issues?? will i need to roll my fenders? Putting them on a 07 subaru legacy gt Link to comment Share on other sites More sharing options...
KartRacerBoy Posted May 12, 2015 Share Posted May 12, 2015 Assuming they are he standard +43 offset, you will have zero issues. I ran those with 235/40s on my lowered 05 LGT on Swifts. No rubbing. Well, from the tires... And shouldn't you determine if there are fitment issues b4 you commit to a purchase? Link to comment Share on other sites More sharing options...
Chris GTO TT Posted May 12, 2015 Share Posted May 12, 2015 Assuming they are he standard +43 offset, you will have zero issues. I ran those with 235/40s on my lowered 05 LGT on Swifts. No rubbing. Well, from the tires... Yep though if they are a more VW offset like +35 you may have rubbing issues. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
justin303films Posted May 12, 2015 Author Share Posted May 12, 2015 How can I tell the offset on them? Link to comment Share on other sites More sharing options...
Dujo Posted May 12, 2015 Share Posted May 12, 2015 Ask the guy you're buying 'em from ... they may or may not have a plate listing what they are ... or you can always measure. I'm sure the Internet can give you a better way, but try using a string with a plumb bob. Tape it to the backplate and then measure the distance between the exact middle of the rim and where the plumb lies. That's your offset in mm. Edit: Do you know the center bore also? Our cars are 56 mm. Smaller (unlikely) will not fit. Larger will require a hub-centric ring. Honestly, based on what they are, they probably fit, but to really be sure, you need to know the bolt pattern and distance, the center bore, the diameter, the width, and the offset. Even then, funky things can happen with the shape of the wheel and how they fit the brakes, especially a BBK, but this particular wheel is probably fine with our stock brake caliper size. And the tire size will matter too. But a regular ole 215 or even 225 should be okay. http://legacygt.com/forums/showthread.php/faq-offsets-sizes-rims-and-tires-gt-xenonk-version-4426.html Link to comment Share on other sites More sharing options...
KartRacerBoy Posted May 12, 2015 Share Posted May 12, 2015 Here's a simple test. Put them on your car and drive them before you pay. Link to comment Share on other sites More sharing options...
Dujo Posted May 12, 2015 Share Posted May 12, 2015 ^ That only works if they have tires on them already. Also, do not drive on a mix and match of yours and his. That will likely not be good depending on how close the outer diameter on the setups are. Fit all four or none. Link to comment Share on other sites More sharing options...
justin303films Posted May 12, 2015 Author Share Posted May 12, 2015 Ask the guy you're buying 'em from ... they may or may not have a plate listing what they are ... or you can always measure. I'm sure the Internet can give you a better way, but try using a string with a plumb bob. Tape it to the backplate and then measure the distance between the exact middle of the rim and where the plumb lies. That's your offset in mm. Edit: Do you know the center bore also? Our cars are 56 mm. Smaller (unlikely) will not fit. Larger will require a hub-centric ring. Honestly, based on what they are, they probably fit, but to really be sure, you need to know the bolt pattern and distance, the center bore, the diameter, the width, and the offset. Even then, funky things can happen with the shape of the wheel and how they fit the brakes, especially a BBK, but this particular wheel is probably fine with our stock brake caliper size. And the tire size will matter too. But a regular ole 215 or even 225 should be okay. http://legacygt.com/forums/showthread.php/faq-offsets-sizes-rims-and-tires-gt-xenonk-version-4426.htmlthere coming off a blob eye wrx so I'm guessing the hub size are the same Link to comment Share on other sites More sharing options...
justin303films Posted May 12, 2015 Author Share Posted May 12, 2015 The tire on them are 245/40-18 I'm running stock hight but from what I see I should be okay maybe a scrap with a full back seat Link to comment Share on other sites More sharing options...
Drift Motion Posted May 12, 2015 Share Posted May 12, 2015 there coming off a blob eye wrx so I'm guessing the hub size are the same Yes, you should do some research rather than waiting for people to spoon feed you Link to comment Share on other sites More sharing options...
Dujo Posted May 12, 2015 Share Posted May 12, 2015 there coming off a blob eye wrx so I'm guessing the hub size are the same I think in this case, your assumption is correct, but be careful about that. The 05+ stis are a different bolt pattern. 245 is gonna be really close. It may rub. It may be okay at stock height. Link to comment Share on other sites More sharing options...
justin303films Posted May 13, 2015 Author Share Posted May 13, 2015 I think in this case, your assumption is correct, but be careful about that. The 05+ stis are a different bolt pattern. 245 is gonna be really close. It may rub. It may be okay at stock height.the bolt pattern is 5x100 on the wheels so I'm good there and ya from what Ive been reading it will be close but I guess we will find out Link to comment Share on other sites More sharing options...
Paparomeo78 Posted June 8, 2015 Share Posted June 8, 2015 I mounted it with OZ Superleggera 8x18 et 48 http://i60.tinypic.com/673am1.jpg http://i57.tinypic.com/o5yu0w.jpg Link to comment Share on other sites More sharing options...
