小灰灰 Posted May 10, 2015 Share Posted May 10, 2015 Did a compression test this morning, 1&3 running 90psi 2&4 running 120psi I didn't do open throttle test, idk if this would make a difference or not. But the car is running fine, and I haven't got into boost because if the shaft play(waiting on replacement now) trying to see you guys input Link to comment Share on other sites More sharing options...
jeffy2.5xt Posted May 10, 2015 Share Posted May 10, 2015 Quick guess would be blown head gasket possibly. Have you checked your coolant and oil? Any smoking on start-up? Link to comment Share on other sites More sharing options...
小灰灰 Posted May 10, 2015 Author Share Posted May 10, 2015 Not at all, checked it this morning Everything is good in that area Link to comment Share on other sites More sharing options...
