Al Thomson Posted May 10, 2015 Share Posted May 10, 2015 so how much movement should there be in the center bearing assembly? I am getting some vibration at highway speeds, checked the main drive shaft tonight and it feels like its in a soft bushing. Link to comment Share on other sites More sharing options...
compsurge Posted May 10, 2015 Share Posted May 10, 2015 Check your wheels for trueness and tires for uneven wear (will indicate your wheels are bent). If the carrier bearing is bad you will need to replace the entire driveshaft most likely. What is your mileage? Link to comment Share on other sites More sharing options...
Al Thomson Posted May 10, 2015 Author Share Posted May 10, 2015 jump put new summer tires on and all were balanced, but vibration was there before with winter wheel/tire package which are on different rims. closing in on 140K miles Link to comment Share on other sites More sharing options...
