06.gt.spec.a Posted May 4, 2015 Share Posted May 4, 2015 Ive had a subaru for 4 years now.i just got engine rebuilt and a new turbo.i check oil every refill.what else should i do or dont do.mechanic said drive easy for awhile till the smoke stops.im just tring to be safe,im ok with engines but not technical.and its still under warrenty too. Link to comment Share on other sites More sharing options...
acumenhokie Posted May 5, 2015 Share Posted May 5, 2015 1 Do not exceed an engine speed of 4,000 rpms until 1,000 miles are on the odometer. Not only does this extend the life of the engine in all driving situations, but it allows the piston rings to seat properly in the combustion chambers, which will prevent oil burning in the future. 2 Avoid heavy acceleration and stopping. For the same reasons above, moderate acceleration for the first few weeks of the car’s life will allow the hardware inside the engine to fit properly in the future. Likewise, light braking will properly mate the pads to the brake disks or drums. Excessive braking before the stock brakes are seated could damage the brake hardware. 3 Do not use cruise control unless absolutely necessary. This allows the engine to rev in different rev ranges, which would otherwise be avoided by cruising at a constant speed. Driving normally in all engine conditions will accustom the engine to those different conditions. 4 Drive using different speeds in both city and highway venues. This strategy will accomplish the same purpose as avoiding cruise control. Allowing the engine to run at different speeds in varying situations will ensure that the internals will be prepared for those conditions in the future. For this reason, moderate, but not necessarily lethargic, acceleration and braking are desirable. 5 Do not miss the first oil change. Using high-quality synthetic oil for the first change will aid all of the processes described above. Depending on the size of the engine and its intake method, each vehicle will have different time periods for the oil changing schedule. Consult the owner’s manual to ensure that you are using the proper type of oil and are changing it at the proper time. Many dealers suggest performing the first oil change halfway through the first oil change interval, and then performing another at the first scheduled change. Read more : http://www.ehow.com/how_5783277_break-engine-new-subaru-vehicle.html Link to comment Share on other sites More sharing options...
06.gt.spec.a Posted May 6, 2015 Author Share Posted May 6, 2015 Thanks for the info.i rarely use cruise control anyway Link to comment Share on other sites More sharing options...
